Thanks! I took "after" measurments with the taller tires on as well. I replaced the 1" factory blocks in the rear with 2" blocks. Getting ready to change out the Ranchos for some adjustable Bilstien 5100s all the way around. Gonna try to raise up the front just a tad more too.
Literally pretty much exactly what i want to do. I've got a 1.25 inch front spacer now and I plan on doing the Bilsteins on the 3rd of 4 height settings giving me an additional 1.25ish. Not as happy as i thought with only 1.25 inches of lift......
Basic bitch, still deciding on 22x12 on 35s or 20s and 7-9' mcgaughy lift
looks good
Can someone with a Summit White '16 or '17 give me their paint code off their glovebox??
Just installed 20x10 Hostile Sprockets with Atturo Trailblade XTs
looks good
What's your current set up? And how do you Like those tires?
- Mike
IG: @BlackPearl_Edition
good choice :)
OK, 2.5 level in front. 1" in rear. 305/55r20.
Before Front 37 1/4" Rear 40 1/4" (to the line on my fender flares)
After Front 40 3/8" Rear 42 3/16"
Ah man, this is my exact truck (minus the level and bigger tires). Any issues with those 305's on the stock wheels? How's the ride and MPG's....
What's it set at? 7? I'm ordering that lift maybe today
Got any side pics
Set at 8", supposed to be level at 8, i measured around 2" low in the rear, but i carry over 1,000# of gear everyday. With 12" wide, youre gonna need to go above 9"to avoid rubbing
Harvest time
89428557-3815-4B4B-8061-8A730DA1B83C_zps
Edited by roundsy
  • Like 5
New to the forum, got this 2016 SLE All Terrain back in March. Not much in the way of mods going to happen as i'm leasing it...but maybe a few items besides the tonneau cover as i'm currently looking for side steps. I do love the truck though, so most likely going to buy it out after the lease term. Just love the looks of the GMC over any other truck right now.
Whats your setup any rubbing?
2.5" level
22x11 fuel hostage -24 offset
33/12.50/22 toyo mt
Rub in reverse around 3/4 lock
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
