Left to right. 14 Silverado with 8" McGaughy's lift and 35x12.5 on 20x12s. 17 Sierra 4" Fabtech lift and 33x12.5 on 20x10s. 14 Silverado with 5" Rough Country lift and 33x12.5 on 20x10s.9e22766a27c0095bd6d3d9929fabc771.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
On ‎2‎/‎10‎/‎2019 at 7:51 AM, longranger said:
Thank you, green is one of my favorite colors and it seems that 2015 was the only year they had this color option. I think it looks really nice with the Saddle Brown leather interior.
You are very welcome, enjoy your new truck!
Just picked up this Sierra 1500 SLT a week or so ago. Did not expect to pick up a white truck but I could not let this one go. Already started doing some things to it not shown in the pictures but I'm super happy I chose this one.
5c61caa5efea6_20190205_0940221.thumb.jpg.5625e89b628b6a2aabfc86d11faddd97.jpg5c61cad7db365_20190204_1239161.thumb.jpg.c8be7da8e01cc813af806d97bba49631.jpg
Welcome to the site, congratulations on the new truck. Looks like you are in one of the parking garages in downtown Seattle with that beam clearance.
Thank You! Im actually in Connecticut and the garages here are small, but just enough to fit until i get a leveling kit then it will be a problem.
6 minutes ago, mitchely03 said:
Also showing my engine bay after my car wash :cool:
Wish mind was clean ??  I trade you snow ( 36" plus) for your grass  ????? good looking truck
  • Confused 1
2018 was also the last year they offered green on the Colorado, it looks like.
I really like the new Deepwood Green color option for the 2019 Tahoe and Suburban.
Don't tell my wife that's an option or she won't let me buy the (white) 2018 Sierra that I have my eye on.
Update: I don't see that colour on the Chevy Canada build and price site.
Second update: I don't see that colour on the American Chevy build and price site either.
Edited by Cpl_Punishment
On 2/6/2019 at 11:07 AM, CovetedStyle said:
It’s a custom underneath the back seat box yah?
Yes, under seat. Fits perfect -- JL Audio CS112LG-TW3
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,074 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
