My 2018 Silverado with a 3” lift (3 in the front 2.5 in the back) riding on 285/75/R18 Nitto Ridge Grapplers
Any rubbing with this setup? Looks good
If I go full lock (40 degrees) and hold it I rub but just ever so slightly. I have factory offset, no spacers, and did not have to trim any plastic or wheel well liner.
This is what I want my Sierra to look like once warranty is out!!!
I'm stock right now.
Sent from my XT1710-02 using Tapatalk
On ‎8‎/‎23‎/‎2019 at 1:56 PM, tarheelkidd said:
2014 Tuscany Edition
Good looking truck!
How about a picture of the 67 Camaro?
Forgive my dirty grill. But updated the front bowtie on my 2015 Silverado LTZ80a2af0cf85b102bfc737b5329e2fd45.jpg
Sent from my SM-G975U using Tapatalk
16 hours ago, JimCost2014 said:
Good looking truck!
Thanks.  Here is the 672012-08-12_17-29-35_583.thumb.jpg.7d4dd60d9acf62874c6fcc6cd5832431.jpg
1 hour ago, tarheelkidd said:
WOW...very clean!  Thought I was on the wrong forum for a second...great looking Camaro.
    • I have 2 choices.
