11 hours ago, psu said:
Loving the wide angle on this iPhone.
That is a good looking truck!
Did not know the High Countries had colored matched bumpers, great cross between the Z71 LTZ and the LTZ package. Chrome and paint, timeless American look.
Did you remove the chrome molding on your doors?
Yes.
Yessir, and thank you! It had chrome mirror caps and window trim too but I swapped them out.
5 minutes ago, psu said:
Yes.
You are very welcome, great "day two" mods!
Nice clean and classy truck !
2016 Sierra with winter wheels. 17" DAI Barretts with Toyo GSI-5.5983dd88e192c4c1ed08dc6e33bb8210.jpg
Sent from my SM-G930W8 using Tapatalk
What running boards are these?
They are APS iBoard wheel to wheel.
They are really affordable and look great. The one thing I would say is that they flex a bit because they have only 3 support brackets. I am thinking of trying to order one more for each side.
3 hours ago, NJ Bassmaster said:
Got me a '17 nali ultimate 6.2 last week. Will get better pics when I'm off
e5969ef02b9323a3629fc46ab0dba977.jpgabe1791b86b54f80bf9d695a400812cd.jpgcb08a7b4b6d4fd543bf7eb4426e452e7.jpg
Sent from my SM-G973U using Tapatalk
Congrats dude !    A spitting image of my 18.   You’ll love it, especially when you call on that 6.2.   It will always put a smile on your face....?
On 12/14/2019 at 10:16 PM, psu said:
Yes.
Do you still have the chrome window trim?
B2FEBCA5-D343-44EC-8074-D5FB5251E4F7.thumb.jpeg.5e1702f40a7cb1ecd6059d12589f5af7.jpegHere’s my 2018 Custom Silverado. 2.5 front leveling kit on Toyo A/T 285/65/20r. Hoping to do some interior upgrades soon.
I haven't posted a photo in a bit, just got her all shined up right before Christmas, weather been awesome, now it looks like rain for the weekend, better park under cover! ?
Edited by SuthrnZ71
  • Like 4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
