Just picked up my TRP so I snapped a pic at the range of course
& an interior shot
Haha! I just saw this exact same pic(interior) on Instagram.. Guess I know who it belongs to now!
Decided to do the 2500Hd conversion narrow my rear end and did a 6/9 drop on 26x9 and 26x12 currently in the shop getting front end installed and aligned and color matching it
Are you going with the 2500 bumper too? Got a build thread or a how to for the swap? Looks really good.
Are you using the 2500 bumper? Got a build thread or a how to with the conversion? It looks great!
That bed looks good nice work
Are u missing the front collison alert ?
We have it on our 14 Impala and we have it turned off most of the time because it's so sensitive. ..
Picked up my 2015 Silverado Rally 2 Edition on Sunday. Had the stripes removed today and ceramic tint at 20% in the front and 35% over the back factory tint.
Truck looks great, still love those wheels. Really like the matching grill too. Why'd you remove the stripes?
Give it a follow my man!
Thanks man! Gonna color match the bumpers, murder out the badges, and potentially level it as well. Wasn't a huge fan of the stripes.
Yes I'm going with the High Country 2500hd front bumper just waiting on the parts from gmpartsdirect the front end is pretty much just bolt on just a lot of small things change that I didn't realize at first like all the brackets that hold the hood the site shield all the bumper brackets ..ill post up a build thread once I complete everything should be within the next couple weeks
I'm planning to do the same but gmc hd all terrain or slt but hopefully it's as easy as ur build keep us posted
Just installed a RetraxOne bed cover on my 2014 A/T. Took off the Retrax stickers, looked dumb with the gold letters. But love the gloss look, it matches the truck perfect. By far the best investment yet!
Looks sharp. What size lift and rubber?
I think you may need more lights too....
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
