yes,
had trouble posting first picture. This site must not let you use image shack to post you're pictures. Which is to bad. This site only takes pictures 1Mb or smaller. Took fore ever to find a site to convert this one.
yes,
If you post using Tapatalk you can upload directly from your phone. I've found its the easiest way to post pictures here.
Sent from my SM-G930V using Tapatalk
Take a photo with the sun to your back, you're not giving credit to your rig with this photo!
What's the specs?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Not sure what specs you want. If I miss something just ask.
2014 Silverado 1500 5.3 LT 2wd with center console in front.
Bilstein 5100's front and rear maxed front to raise about 2"
Removed rear factory block
Wheels are a +30 offset. Don't stick out of the fender
Also installed a afe intake with i2 diablo. Custom tune in the future.
Tint: 5% every window 35% entire windshield
Custom exhaust
I think that's it
I will get more pics today. Thanks for the advice. This was the only pic I had on my phone and didn't want to not post a pic. Edited by Pt187
Custom exhaust
I think that's it
What tire size are you running?
lol I knew I would forget something.
They are 33x12.5r22 nitto ridge grapplers.
No problem.
TBH I'm not really sure. I recently bought the truck. Drove it around stock for like a week while I ordered everything and didn't pay attention to mpgs. Now I'm getting around 16.5 average. That's mainly city driving
It's way better then my 2007 nbs vortec max with leveling kit and 34" at tires. That dog got around 10-11 mpg. Loved the power of the 6.0 hated the 4 speed trans.
b7425e1a2db31feb42f1524b3ce3a9d1.jpglike that?
Is there a lift or just Level Kit? What size tires? Looks Great!
Zone 4.5" lift and 305/55/20 Toyo AT2s. Thanks
Pretty sure that's a 4 inch Zone with 3 inch rear block and 33" toyo at2's
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
