Very clean looking truck! Looks like a lowered truck done right. Is it 4x4 or 2wd?
Sent from my SM-G930V using Tapatalk
It is a 2wd
It is a 2wd
In this case that's great. Usually lowered 4wd trucks are hacked up. If you don't mind me asking what did you pay?
Badass. :thumbs:
This is my cup of tea. The lowered looks great, but this is just right to me!
E8ECCD96-44E7-4F1F-B794-FF9A80C01FA8_zps8CB7B838-C49D-41D0-87A7-3F21DB69F443_zpsMy contribution to this thread, no "grandpa mods".
2015 Gmc Sierra Slt 2wd
Fox 2.0's front and rear, Cognito Uca's, Weld Cheyenne 17x8.5 and MT Mtz 33x12.50's.
Great looking setup!
How do you all like this one!! c75bee8d5063914d08314e61a4c8b79e.jpg39913da1631d26c2866540074424d726.jpg
I think it looks great. I'd prefer the wheels not to have the red face plates, but your truck does pull it off well.
I'd rather look at and drive a truck like this with a nice lift and clean wheel tire combo and nothing else than a leveled truck with stock wheels and a light pods and bars, and steps, and mud flaps and what ever other crap hanging off it.
Here is my 2014 Silverado High Country that I picked up a few months ago. I am not into lowered trucks with big wheels but I just could not pass up the deal I got on this. My friend is the used car sales manager at Planet Ford in Spring, Tx and they got this truck on trade in and couldn't sell it at the dealership because it had too many mods and no catalytic converters so he gave it to me for wholesale!
The truck is "UNDER CONSTRUCTION".
I will be raising it back to stock height with a leveling kit or maybe a 3.5in- 4in lift
Adding the 22in OEM Ck158 wheels (if I can ever find a set) LET ME KNOW IF YOU CAN!
Adding a muffler to it because it currently has long tube headers with a small resonator. SUPER LOUD but going to sound nice when I tame it.
The front end is also a 2500 conversion. Haven't even taken the Duramax badges off yet.
LET ME KNOW WHAT YOU THINK! Remember this isn't my style but it does look pretty awesome as it stands.
15994649_10211960525232240_4567871161622768899_o.jpg 15972487_10211960524912232_5298853879203725209_o.jpg 15875203_10211960525432245_8490744396048803925_o.jpg 15936472_10211960534712477_2833204966629374076_o.jpg 15937038_10211960528792329_8058973411876891848_o.jpg
Looks great, makes me want to do a 2500 front clip swap.
EXACTLY
My 2017. I just finished installing 5100's front and rear. Let the addiction begin!
  • Like 3
What is the wheel offset?
looks good . your tires are they the same as 285 ???
That is a clean combo, car rims in a massive size with stretched tires? I guess it's clean because it doesn't get used :dunno: I bet it drives real nice though :crackup: Atleast that other stuff you listed is actually mostly useful and can help the truck in doing oh I dunno truck stuff....
To each their own though, pretty easy to spot what owners do and use their trucks.
Tyler
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
