@Ssguy85. Thanks. That does sound pretty good. Im looking for quality>quantity, so loudness isn't priority. Ill look into that one more. Was looking at the Borla S type but man are they pricey. Pypes has a Violator muff that sounds decent also, but its really hard to tell through a video. As for drone yeah, getting used to that. Im on my 3rd oem muffler due to the little flapper failing. Get the high pitched whistle when it comes out of v4, and when in v4 around 40 mph it gets pretty bad. Like a large subwoofer on a bad note. But again, thanks
I'd look long and hard at Corsa. Seems to fit the bill.
Btw, quality = $$
I know more money usually mean better quality. But, Flowmaster is a quality muffler, especially since the one I got was black so I think it's a rust protector or something. Also the pipe the shop used for mine isn't mandrel bent, but I'm sure they're stainless so shouldn't rust. You're not really going to feel the difference between mandrel and non mandrel bent, it's mainly just for looks. Of course mandrel will flow better, but again you won't feel it. I've never like paying that much just for a pre-made cat-back exhaust. I just went to a local shop that's good with exhaust and they did everything from the muffler on back. Parts (Super 44 muffler, pipes and black chrome tips) and labor was just over $300 and I had exactly what I wanted. I'm picky so if I looked for a cat-back I don't think I would find exactly what I would have wanted (same muffler and the tip locations).
I wouldn't be so sure your muffler shop used Stainless pipe. They normally use Aluminium coated high carbon steel 16 gauge pipe. I would ask to be sure...never assume!
RT
RT
Yeah, any of the times I've dealt with a exhaust shop and the pipe was a 'screaming deal', it was aluminized pipe. In our climate, that stuff will rust ASAP.
Attached is a video of my new dual exhaust with Magnaflow single in dual out 18", on my 2015 5.3 LTZ Z71 CCSB Silverado. Too loud for me in the cab at low speeds. I unfortunately removed the flapper & resonator. Will have to go back and fix eventually.
https://www.youtube.com/embed/5WdzFXqKZ20
Edited by txchevy4ever
^^that sounds mean man!! I like it!
-Skeet
It's awesome at idle but way too loud otherwise between 1500 and 2000 rpm and when 4 cyl mode kicks in.
I love the sound and how loud my Flowmaster Super 44 is. It can be obnoxious like a loud Harley which can be funny sometimes I just can't stand glasspacks, makes it sound like the exhaust is about to fall apart.
I have been debating about exhaust for a while now and I really like the cat back 45 behind each wheel but being in Canada I've been quoted $425 +13% tax for a 18"magnaflow with aluminumized pipe plus I have to provide tips or order them from him. So I'm looking at 425 for exhaust Plus 100 for two tips which comes to $525 +13% which is $593 taxes in.
If I do it on my own with just a muffler and tip leave the flapper and resonator it would cost me me about $150 for stainless steel 18" Magnaflow muffler and around $80 for a nice tip. (like a dual tip) Plus 13% tax and I install myself.
$600 is pretty cheap for a dual exhaust set up, installed. As 07Softail said, "Aluminized Pipe" will rust, so that's part of the low pricing you have. Also $50 each for tips is also pretty cheap, I'm in Ontario Canada myself, and if I remember correctly, the "Magnaflow" tips I had installed on my 07 Silverado were pretty close to $100 each.
Overall, my system, back in 2007, cost around $900 installed. That's a single in, dual out, with split rear exit using custom stainless pipe, and all Magnaflow parts. All fabricated and installed my a "Magnaflow" dealer. My son now has the truck, and the exhaust system is fine.......even the tips, just a little elbow grease and some chrome cleaner, and they still look as good as new.
I guess what I'm saying, is that sometimes when a deal sounds really good, maybe the quality has something to do with it.
Edited by revitupfaster
can you make a video of sound when you are driving, and v-4 mode that sounds exactly like i want. but i do make a lot of highway trips and 2 hrs can sometimes get annoying. if you could that would be awesome
Yes, I'll try to do so this evening on my commute home.
If you leave the resonator on you wont notice much difference at all. Im thinking about trying the flapper before the input , duel out , res delete. I already have a brand new full exhaust from my previous buyback that I can scavange parts from. Just not shure if I need the flapper bypass like the Borla(I think it was Borla).
Previous truck was 14 in Maggie with turndowns. V8=MEAN, V4= HORRIBLE Blackhawk chopper LOL
edit- the best part of the vid was the hand off of the phone to your kid. The reflection looked like a funhouse mirror .haha Sad thing is , that is about my actual porportions LOL
Edited by scott19677
LOL< my 5 year old and I are both built like big boys, but not quite as big as the reflection showed! He likes helping around the house and on mechanical things.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
