On 9/12/2018 at 12:52 PM, Rally_18 said:
I'm looking into doing a catback exhaust system don't really want to hack the stock system up in case i want to go back at some point. Thinking about the Carven Exhaust kit with the progressive muffler anyone have experience with this setup or company?
I just got my Carven TR with carven 4" tip installed. I had them weld it in where the stock muffler was. I kept the resonator in and got rid of the flapper.
It sounds great i think, i like mine on the quieter side and this one is just right. It has a nice growl at startup and idle and when you get on it.
No drone but obviously you can tell there is an exhaust on when you are driving. I gotten used to is, first day i was like "ohh man, is this too  loud?"
I did remove the flapper and in V4 mode it sounds like a military helicopter is following me haha soooo no V4 for me going forward.
Go for it, you will like it. The muffler shop guy was pleasantly surprised when he started it the truck up because the muffler looks like a ricer muffler that would go on a civic lol
Edited by Ozer
Good deal man i ended up going with the Carven Progressive Catback. I love it sounds great and looks amazing build quality is top notch!
Good to hear, you made the right choice.
Add a sound clip if you can, id like to see what the catback sounds like vs my splice in job
On 10/3/2018 at 5:31 PM, Breedsrt said:
5.3l with speed engineering longtubes and catless Y pipe though MBRP part# S5086AL
Aluminum 3.5” exhaust. Y pipe came with the adapter to run the 6.2l 3.5” ball flange. I just had to order the 3.5” ball clamp and chop down one of the pipes to make it fit my 2018 RCSB z71. Truck is filthy in the video. First day in like a week it hasn’t rained.
i am in love. that sounds sooo good. are you happy with the speed engineering headers? i have been torn between those and the texas speed
No real complaints with the headers at all for the price. I would upgrade the headers to y-pipe exhaust clamps. The ones that came with them had trouble sealing. I was going to order Texas speed headers and y pipe but at the time they were out of stock and had no eta on them. I only had a week to get all the go fast parts in so the shop could get my cam swap and bolt ons done while I was on vacation. Me being a Texas guy would have liked to support my Texas business but it just wouldn’t have worked for my time frame. I wouldn’t hesitate to use either one imo.
how much power did it end up making? also what cam did you use?
372/365 with no correction factor through factory cat back exhaust. Can’t remember cam specs. It’s a BTR boost cam spec’d out by the shop that did the work.
I'm looking at maybe the Borla Pro XS to replace my stock muffler.  My truck is a 2018 Silverado 5.3 w/just over 1K miles.  I just want a little more sound, hopefully deeper too.  I do not want a loud obnoxious exhaust.  Anyone know what Borla model # is for my truck?  If not, anyone know what size in/out I need, then I could research and find what model I need.  I looked under truck and it appears to be offset intake and center output and states reversible.  If it's 3" then maybe this is the one I want.  Borla Pro XS 40359 .  Thought I'd ask here before I order though since someone may know what I really need.
Thx in advance, Don
This on a 6.2?
Thx in advance, Don
I believe its 2.75" in and out
2 hours ago, SirenRed16 said:
"I believe its 2.75" in and out"  Thanks SR16, I just home and measured the outside diameter of pipe in and out and measured 70mm which converts basically to 2.75".  According to the Borla website they do not sell the Pro XS in a 2.75".  I know little to nothing about exhaust changes.  Would it be normal for a exhaust shop to maybe use adapters to convert the 2.75" pipe to 3" in order to be able to use a muffler designed around 3"?
Any decent shop can make it work. Order a 3" and you should be good.
This on a 6.2?
Negative. This is a 5.3 rcsb truck. This was a boosted cam swap with speed engineering headers through stock cat back exhaust. Didn’t have the 3.5” Mbrp on it before the dyno tuning.
    • I really appreciate the response.  I guess I was confused about torque angle vs torque angle yield.  The individual bolts don't have a warning on reuse but the part number for the LCA nuts does.   Regarding the purpose of the moog grease fittings on their bolts .. Guessing to reduce possibility of corrosion locking the cams or seizing to the bushing inserts.
    • The top speed is software limited, I don't think there's a way to change it without de-doing the whole truck. If you can get a CAN log per my above post we can try seeing if there's anything obvious going on. What happens when you plug the truck in to charge it, does it ever fully charge up or does it stay at low battery %?
    • The LCA bolts are NOT a one time use fastener.  GM does not have them called out as such at all.   They are torque plus degree, but not a one time use TTY.  Nowhere in the service manual does it call out for replacing the LCA bolts for being one time use.  The factory spec would apply to the Moog bolts as well.    I see two things different.  The Moog bolts are greaseable (which I see no point in) and they don't have one of the washers welded to the bolt like the factory bolts, so they can be used in all 4 positions.      Think about it.  The LCA bolts are now the alignment adjustment point, instead of the UCA bolts like the prior generation.  A bolt that is meant to be adjusted for alignment...would it make sense to make it a one time use component?  How would you get an alignment done in the first place?  You couldn't.       Also.  What TSB exactly?  There is no TSB that I see for 2019-2026 for over-torquing LCA bolts.  There was a PI, PIT5533C, but that covered 2014-2018 body trucks for re-torquing LCA mounting bolts.  But those trucks to a 2019-2026?  Not the same, so PIT5533C does not apply.
    • Nice looking setup!  Is this the kit you got?  If so 211 is a great deal!  https://accessories.chevrolet.com/product/trailering-camera-system-86584184   My TT came with a wireless rear camera but it only works on an app or a separate screen they sell so I've decide it's not worth the hassle since it keeps disconnecting and with wireless android auto it's a hassle trying to connect my phone to it.  So I've been thinking about adding the GM camera so it's integrated into the rest of the camera views.   I also found this one which seems to be a different PN & retail price that explicitly states the invisible trailer view https://www.shopchevyparts.com/chevrolet/2024/silverado-2500-hd/electronics/85825715-silverado-2500-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92326971.html?sort=2a
