I'm looking for the best way to lower the rear of my 2014 2WD 1500 about 1.5". That will still give it about a 1.5" rake which should mean level when I'm towing. I considered drop shackles but was reading about removing the rear lift plate that's between the axle and spring.
My question is can the leaf spring sit directly on the axle or is some sort of spacer / bushing required for proper alignment and isolation?
Edited by mjw930
I'm thinking about doing the same, let me know how it goes if you get to it first and I'll do the same.
Thanks guys, I may get to it this weekend, if the to do list isn't too long :)
Take pics of the process!
If you remove the blocks, make sure you install new U-bolts and retorque after two weeks.
It's interesting you would say that. I know there's a lot of opinions on this and other forums. Many saying to use new and just as many saying they didn't and nothing bad happened so I did a search looking for what I would consider a reliable source and came up with this:
HOWEVER, read the following transcript:
John,
Quality aftermarket u-bolts are made to SAE standard J429 using SAE1541 steel. 1541 provide a 150,00 PSI minimum tensile strength, and 130,000 PSI minimum yield strength and a 120,00 PSI proof load. So stretching, or exceeding the yield is not something one needs to be concerned with.
The reason u-bolts should be replaced after they have been torque is because the threads are rolled, not cut.
Because of this the threads are distorted when torqued. This distortion will not allow the torqued to be maintained when the nuts are loosened then retightened.
Because loose u-bolts are the main cause of broken springs, we suggest that they be re-torqued. While the springs are new and the u-bolts are new, the rest of the suspension is aged and will have wear. It is common that the new parts receive additional stress than the older parts.
Re-torqueing continues to move the nut up to new threads.
Bottom line is we recommend that the u-bolts be replaced once they have been torqued to spec. Whether one does so or not is their choice.
-Mike
SO, since removing the block moves the nut 1" further up the threads you are using virgin threads and should be able to apply the proper torque and have that torque retained. Of course, if you decide to go back to using the block then you need new bolts because you will be back into the area of the threads that were deformed by the original installation. No new bolts needed for this operation, only if I go back to using the blocks.
The re-torque after two weeks perplexes me. Are there guys running around dealer lots re torquing u-bolts? How is it the factory can install them and they are good for years but I need to re-torque?
Perhaps this is due to the explanation above where old parts wear different than new, which seems a bit far fetched to me AND I doubt the movement on the bolt would be more than a few hundreds so you aren't going to get into any significant "new" threads as mentioned above. Since the Truck is all of 2 weeks old I don't think the old parts vs. new is an issue but I will check just to see if there's any truth to the legend.
Has anyone who's played around with u-bolts ever seen them loosen up after a few hundred miles or is this more urban legend than sound engineering?
Edited by mjw930
I have found plenty of pictures of trucks with the front ends leveled but can't seem to find ANY of the new Silverado or Sierra with a leveled rear suspension using 1-2" drop shackles. Anyone have any pictures?
I do, here is mine with the belltech rear 2" drop shackle kit on my 2014 All Terrain. Before and after....
before
after
Don't let the after fool you, the street in front of my house is on a slight incline and the sun was to the left of the truck, it sits level now with 6.25" from top of tire to bottom of fender on both ends.
Awesome man, I was just wondering how level it actually made it since some leveling shackles still leave a slight rake in the rear. I hear people talking about removing the blocks from the rear, did you just install the leveling shackles only or remove the blocks as well? Beautiful truck btw!
Shackles only, I mentioned the blocks to my buddy whos shop did and he said to only do the shackles. The block looks to be 1.5-2 thick.
If you do the shackles it will take 1-2 hours, you have to drop the rear hitch assembly to get the shackle bolts out from what the shop told me. I don't mind the slight rake, looks way better than the stock look. I wont ever run a larger tire so that is why I went this way over the front lift kit (moves the lower shock mounts up 2" instead), plus then you have to get a front end alignment as well.
If you do the rear you will need to take at least 2 360° turns out of the front headlight adjusters to get them down some. It is super easy and that is a estimate, even with 2 turns out the lights are still up a bit from the factory setting(which I think is too low, I am sure it is low incase of weight in the bed which then levels the lights out).
I'll be installing shackles and removing the blocks on mine over the holidays as well. I'll try to get some before/after pics up. Tjay did you cut your bump stops down, replace with shorter bump stops or did you even mess with them?
If you do the shackles and blocks you will be dropping more than the 2" the shackles provide. I did nothing to the bump stops.
What brand you guys using? Where did you get them?
Install them yourself?
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
