Not sure I understand....you want to do a 3/5 but don't want to change springs or struts?
that's right no spring or struts they tend to get their own alignment after 4k miles that's what i have gone through on my nbs i don't know about their new stuff to till the truth .
Your aluminum control arms limit your options like they did for me on my 2015 Z71, meaning no spindle options for you unless you are willing to go and buy some steel control arms (which isn't all that expensive actually). If you want to go down 5" in the rear you are definitely looking at flipping the rear + cutting/removing the rear bump stops. Depending on how much weight you haul/tow, you might be able to get away without having to cut off the rear bump stop brackets.
i don't haul or tow with it , swapping ain't what i have in mind if it doesn't fit will wait for some company to do it eventually thanks man .
Only one that will give you a 3in drop without struts/springs is the DJM control arms, most a spindle will do is 2" and I've heard the McG spindle is more like 1.25 but no first hand knowledge.
do you have a part number for djm control arms ?
spindle will net 2" but i don't think they made any for aluminum trucks ? do they ?
thanks bro .
I've read in this thread that a 2" drop has some people shortening the driveshaft and causing pinion angle issues? :confused: So...are we saying we can't put enough load in the box to squat the rear 2" without damaging the truck? :rolleyes: Taking the shocks past travel and...and...and??? ​ ​That isn't much of a load.
LOL.... I did a 3-5 drop with no issues at all.
RT
Did you guys have the 1.25" factory block in the rear? I want to remove mine but do not know what u bolts I will need or if I can use the same ones?
I yarded mine out and just tightened up the stock bolts again. Even if you feel you need to replace them the stock length is a non issue.
Sent from my PURE XL using Tapatalk
Hey guys! First post. Lots of good info. I did mcgaughys 2 inch drop shackles today, and pulled the block. Still got about an inch in the rear... Seems maybe my truck was a little higher than most. Before drop, rear measured 39 3/4
2016 Silverado custom. Dbl cab 2 wheel drive.
I have read the entire thread but i couldn't make my mind set on what to chose for my truck so here goes ,
2014 chevy silverado 1500 z71 with aluminum front end
i want to lower it to 3/5 at least , don't want any spring or strut options because alignment issues
DJM or mcgaughys who ride great and don't ruin anything with 4wd stuff they didn't specify any lowering options for 4wd trucks
Belltech ride great as far i can used in another truck but alignment is an issue even if do it right it will need another after a while
I used the DJM 4" control arms and a Street Edge flip kit on my 2014 4x4 haven't had any issues with the 4wd. My truck also came with aluminum control arms and spindles.a82a3cf53977b42fb85804a53ae95124.jpg
Sent from my SAMSUNG-SM-N910A using Tapatalk
currently on McGaughys 2/3.5 drop kit with my '14 Z71 but already want to go lower. Thinking about going with the DJM 3/5 drop to get alittle more aggressive and fix the front alignment issues
Since this site helped me so much I thought I would add my finished project along with some technical information.
Truck: 2014 GMC Sierra 1500 V8 Crewcab 2WD
Lowering Kit: Belltech 996SP
Wheels: Black Rhino Traverse wheels 22"x9.5" offset 25 - had the outside spokes masked and inside done in a gold powder coat and then clear powder coated.
Front Tires: 285x45 Yokohama Parada Spec-x - no fitment issues - no mods to inner fender skirt
Rear Tires: 305x45 Yokohama Parada Spec-x - no fitment issues - no mods to inner fender skirt
Lowering Option: I went with 3/5
Installation - I did this on jack stands in my driveway. I am an occasional shade tree mechanic. Probably had 60 man hours or 5 weekend days to complete. On a scale of 1-10 with 10 being the hardest it was probably an 8 doing the job on jack stands by myself. There is NO frame notching with Belltech's 996SP kit. It was very time consuming and doing the flip kit in the rear required some ingenuity because the axle had to be suspended and tied high and held while I did all the spring work. Cutting off the bump stops was a pain. I had to use my plasma cutter. Drilling out the 3 rivets per rear leaf spring hanger was a pain. Used an air chisel after drilling a hole down the center to knock off rivet heads and then air punch to push them out. Replaced all the factory bushings with poly as well and that was a major pain removing the old that only had 14,000 miles on them and replacing with the new. After I had everything complete the last step was installation of the transmission spacer to correct the driveline angle. When I rolled up to the transmission on my creeper I discovered my driveshaft had fallen out with all the moving of the rearend that I had done. It was resting on the frame brace so it never it the ground and was why I did not notice it. It made it easier to install the spacer anyhow. When I went to re-stab the driveshaft after unbolting the rear u-joint I was like holy crap this thing may not go back in because the snout was bottomed out in the tranny. I managed to wedge it in there and then pulled it back to fit into the rear end pinion. Belltech says no driveshaft shortening necessary. I read the driveshaft should insert on the tranny spline 70%. I will go in and measure the distance. I can tell you there is zero driveline vibration. The truck drives perfect at very high highway speeds as well as low speeds. About the only mistake that I made and I see no reason to change was I am running the Belltech shackle at the rear of the springs rather than the factory shackle. I did not see the table in the Belltech instructions that says for the 3/5 option use the factory shackle. The rake on the truck to me is perfect. Just a tad bit higher in the rear than the front. The profile is amazing.
Alignment - Belltech says back to stock. No issues no problems cost me $71 out the door.
Final ride quality - exactly like stock. Truck drives absolutely perfect. I was surprised. Nothing rough, bumpy, springy like a low rider - nothing. Just like stock. Apparently Belltech did a great job on this kit.
If anyone has any questions let me know and I will try to answer them or take any pics you may need of the installation.
Great looking truck. Could you snap a pic of the rear pinion angle? I have a slight vibration put in 6° shims but I think 4° would have solved it. Thanks
14 Silvy - I will get my angle finder out and take a pic this weekend measuring the angle. I will post it up on Monday for you.
    TopBo
    TopBo
  • Who's Online   3 Members, 0 Anonymous, 1,537 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
