great pictures billg72340. truck looks great. Who did you order from? Wondering how long it took to get out to you. I ordered mine from switchsuspension. They said it could be 10 days. I'm hoping that isnt the case. I'm from PA so not that far off from Ohio.
Thanks. Ordered mine from Summit but they had drop shipped from factory in CA. Took 5 days UPS.
Sent from my Pixel XL using Tapatalk
Originally I used 4 rings without the spindles and dropped 1.5" then installed the spindles and added a ring back on which gave me 3" total.
Did you do the install yourself? I've got the drop struts in the garage but am a bit worried about replacing them on my own. Heard a few horror stories about getting the right spring compressors to get the job done.
I didn't need to use a spring compressor. My weight was enough while someone screwed the top bolt on to hold it in place.
Only thing about lowering these trucks with struts and springs in the mix, is the lower you go the front wheel moves back in the wheel well and isn't centered.
My front wheels are perfectly centered. However, camber is a bit of an issue after the springs have fully settled over a few thousand miles.
Front struts are fairly easy with the right tools. I had problems getting the lower ball joints popped with a hammer and ended up borrowing a puller. Most auto parts have loaners.351c39721b0fc0da229661bbd4a2bf58.jpg01dc7d930e1384b5e7e23a5605bfbcde.jpgc2867390d33dc5748660c01458aed498.jpg7a73752ee1b5f2d5985bfa76f30005c1.jpg
Send me a side pictire
After reading through all 90+ pages my head hurts and I still can't make a decision.
First off I have a 14 Sierra RCSB Z71 4x4, with 285/45/22 and currently have the back leveled out with 2" shackles and the factory blocks removed, after owning it for 2 weeks and having the shackles in for 1 week it needs to go lower already haha
I am thinking I want to for about a 2/4 or 2/5 drop, now figuring out the best way to do that...
I was considering going with Beltech 25004 2" shocks in the front and either DJM or McGaughys 4 or 5" flip kit in the back. I might even try just the shocks first and see how it looks with my current rear setup, will have a couple inches of time but that's better then the 4+ it had before..
My other option is flip kit, was looking at DJM, I believe I would use RK2507-6 and since I already have 2" shackles I think that would give me a 4 or 5 inch drop correct?
Or would you recommend McGaughys flip kit over DJM? I was having a hard time finding the right part number on their site tho.
And for the back I haven't decided on a shock, I see rcsb guys saying the beltech is too stiff on our short trucks.
Other question do all flip kits require cutting off the bump stop mount? Cutting on my new truck with 9k miles makes me cringe a little but I'm sure I could get over it haha
So basically just looking for recommendations, I have been reading for days and I just want to order stuff so I can get to work on it!
Sorry for the Wall of text! Haha
What's up guys - been following y'all for years. Just got done lowering my 15 with RC 2/4.
Pics or it didn't happen! :P haha
I think i have a plan of attack for my truck unless someone can tell me a better alternative
I see lots of complaints about turning radius with drop spindles so my plan is Belltech 25004 2" drop shocks, and that way if i ever do want to go lower i could add spindles.
the only issue i have read about with those is getting proper alignment but from what i can tell a set of Belltech 4955 bushings should get it where it needs to be.
and for the back i think i am going to leave it with shackles and blocks removed for now, I have seen a few pics in this thread with guys with that setup and it looked good, then i think ill go with some Belltech 2212FF rear shocks, anything has got to be better the the stock rancho's
Thoughts on going this route? anything im missing?
Top pic is how it sits now, bottom is stock
If you.only have a spindle in front. Your camber won't change
I tried posting pics but it said they were too large. Tried looking all over to figure out how to do it and got nowhere..
I was leaning more towards the Belltech 2" shocks, since i want to change shocks anyway. unless there is a significant down side
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
