If I go any lower I can't drive it. Already damn near ride the upper inner fender if I have more than one other person in the truck. LOL
I'm at 4.5 in my rc right now my front end sits so low because I have small tires. You might want to get a smaller tire. Which will give you mkre room in the fender but also lower the truck.
My front valance hates me though but I'm ok with that
Yeah. These are 29 inch tires in the front right now. Still have the stock 31 on the back. Doing 24s all the way around so I'm gonna end up clearancing the inner fenders some. I just ordered a 2 piece drive shaft conversion yesterday because I'm rubbing on the cross member on large bumps and I still want to go down another inch in back.
You either need to tub the front fenders of run a 25 series tire in maybe. Maybe squeeze a 30 series
I'm running 17s 28"tire front and 30 rear
Remember I told you about the tire getting pushed back into the fender well? Take a look at the inez k2 kits. They didn't even correct for that. That kit set at 4" is worse then your teuck set at 5. Ill pass on that inez kit. Most people don't look at things like that
I don't see that problem based on the pictures posted on the Inez Hotrods facebook page (see example picture below). I purchased their 3-5 kit (which I have not yet had installed). The main thing I liked about their system of replacing the control arms is that the alignment of the wheels stays true unlike using drop spindles.
20882393_166750353872579_856074399418406
When you lower using springs and or struts it changes the horizontal geonomtry. Look at the space between the front of the front wheel well and the rear of the front wheel well. It already started pushing it back
Even my 1" drop from a belltech strut moved my wheel back. Crappy side effect.
The upper arm is angled back some so as the suspension compresses, the wheel moves back. I think it makes for a better ride but it just looks like shit in my opinion
I'm limited on ways to lower a 4x4. There's no spindle that works on a 17 4x4 otherwise I would've done that with the djm arm
2015 Crew cab LT 4x4 with Mcgaughys 2/4 kit(34100). Just traded it for a 2wd so I could go as low as i want. This was my last pic, I'm gonna miss this one. post-161740-0-53326000-1507264278_thumb.png
2015 Crew cab LT 4x4 with Mcgaughys 2/4 kit(34100). Just traded it for a 2wd so I could go as low as i want. This was my last pic, I'm gonna miss this one. Screenshot_2017-10-06-00-27-04-1.png
You could have gone just as low with the 4wd but I prefer 2wd anyway
Not without way more work, money and wear.
Well not really. Only thing that's really different is the front cv shafts
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,533 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
