anyone thinking about the michigan metal works control arms they are having a "name your price sale" going on now. suppose to be a 2 inch drop and it also centers the wheel in the front fender.
I might grab a set in thr near future.  But theres more to them then just bolt in
It’s hard to see because everything is black but I had the truck lowered in the rear to level it all out.
Dropped shackles and block removed
Now I just need to figure how to just adjust the headlights (they’re pointing up now that the truck is level)
I should mention the ride feels the same and it did make a difference getting in and out of the truck, it’s easier for me now
Theres a screw you twist. When i get home ill snap a picture
Awesome, thanks [emoji1362]
Not a very good picture but should give you good starting point. The screw is located on top of the headlight8ee2e5b5942f17df1843fe74af8b374a.jpg
Got it, thanks!
15 minutes ago, DESERT DOG said:
Finally got around to taking pics after it was lowered. Now to figure out what wheels to go with.5c0af031ed8f2_bFrWzZO-Imgur.thumb.jpg.2f9472cb4c1f39f59fa3a1557415521f.jpg
Im in the same boat. Sold my wheels today so now im riding on those exact stocks.  Only thing i like about them is the ride.  I found what wheels i want. But i just dont know if i want to spend 4k on wheels and tires
I went up 1 inch all around the other day, so I'm at 3/6 and cannot be happier. Took it to a different shop this time and they found a few things done incorrectly the first time around. I'm not one to get out of paying for no reason but I think I'm going to pursue this a little bit deeper.
What was wrong
What was wrong
Most of the back half of the truck was left untightened. The owner of the shop that picked it up is going to make me a full report and I'm hopefully going to pick it up tomorrow morning.
It sounds like you made you're mind up on which wheels anyways. I can't make up my mind, the only thing I'm sure of is they will be 22's.
I had 22s. And took them off. The ride suffered
Are you going to 20's then? I think the 22's fill the wheel housing a little better, but don't want 24's because of the ride issues.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
