1 hour ago, pillman said:
More confused now! I want to drop my 2018 4WD RCSB Z71 Silverado 3" in the front. Just when I thought I had my answer with the combination of Belltech 2514   2" drop spindles combined with Belltech 25004 struts set at 1" drop, I come across the Belltech 15002 coilovers which it indicates are not only compatible with 4WD's (as there webpage does not with the spindle/strut combo) but are adjustable from a 1 to 3" drop? Why wouldn't I just go with the coilovers and set to 3" drop?  Will these move the wheel off center more than the other option???? There must be an advantage to the spindle /strut for 3" front drop? Or is there? If you went with what Belltech's webpage suggests for what I want it looks to me like the coilover is their recommendation?
Use spindles and the coilovers.  The geometry of the arms on these trucks suck     spindles will help it
Sorry for my ignorance! Coilovers and struts are two different things I understand. Would you use the spindles with the coilovers or with just the struts? and why?
Thanks
Thanks
If you have the extra money id get the coilovers.  But when lowering nnbs or k2 trucks. Always atleast use a spindle.  Im swapping my struts out for twisted metal workz coilover setup
Beauty! Thanks Nasty! Sure appreciate your feedback. I'll check into the Twisted Metal Coilovers!
Cheers
208e2b6540afbc41b5ddf58647664d82.jpg317c3d36618e6694d4b0343492ca48ba.jpgNew to this site here is my 2018 Sierra Denali with a 2/5 drop.
Welcome to the site, Awesome looking truck!!!
Thanks been hanging around awhile finally decided to post
I like it but 1 thing bugs me. The front is higher than the rear
Correct by about a half inch to an inch thinking about adding rear helper bags the suspension is real touchy with the magnaride system
You could adjust thr shackle as well if im not mistaken
I thought about raising the rear just a tad to level out still on the fence.
Nice truck. 24”s I assume? What tire size?
krunch
1 hour ago, Nasty said:
Thanks Krunch But they are 26's W/305/30/26 tire.
Cheers
Nasty,
Im also interested in why you would choose the coils over the struts in this situation. This is the exact decision I am about to make. Would the coils / spindles make a better ride or are their other gains to solving this vs using struts / spindles.
thanx,
krunch
Edited by krunch
