Went ahead and ordered them. Also ordered 1.5 inch drop shackles for the rear leafs, since I’ve already pulled the 1.25 inch blocks out of the rear, that’ll give me 2.75 drop in the rear and 1 inch drop up front. Should maintain just enough rake to make me happy, and the ride shouldn’t be too affected.
Installed the max trac 1” lower springs. Install wasn’t Terrible ( though I thought my spring compressor was going to snap) truck rides smoother, floatier ( don’t think I like that) and it sits about an inch- 1.25 inches lower. Perhaps they will tighten up as they settle. Overall I’m happy with the look, I’ll be doing the 1.5 inch lower rear shackles tomorrow
Just FYI for everyone... I can no longer say anything positive about the IHC 4/6 lowering kit. I have broken both lower ball joints due to the extremely cheap Chinese joints used in the kit. This was confirmed by my shop. I have since had both lowers replaced with Moog joints but am stuck using the Chinese upper ball joints because they are smaller than any GM upper ball joint available in Moog.
Total cost to fix the joints and associated damage and misc... $1700.
While the IHC crew had great customer service I can't in good conscience tell anyone to buy this kit until the various issues they have are adressed.
Lack of QC - I had to slightly drill out one of my spindles to accommodate a missized upper ball joint.
Lack of grease in ball joints - was told they were pre greased
Cheap materials - extremely cheap ball joints which becomes a safety issue. Luckily mine both sheered while reversing into a parking spot.
Edited by Goinovr
That just sucks. And one of the biggest reasons stopping me from lowering my truck. Imagine that happening to your 7000 lb vehicle at highway speeds.
I highly recommend the Twisted Metalworkz Uppers.  They are fantastic and given the lack of confidence in the IHC kit it would be worth the $475.  They include the ball joint.
link: https://www.twistedmetalworkz.com/collections/control-arms/products/2008-2018-silverado-sierra-camber-correction-control-arms?variant=11703967285295
Edited by UofAZCats
I was looking at these last night. I like the captive inner ball joints. I added them to my parts list.
Honestly, I'm not surprised. @Nasty has preached this for the last 2-3 years and many other people running they're kits haven't been impressed. Belltech or MCG for life.
Another one bites the dust
Sent from my SM-G975U using Tapatalk
I stuck up for IHC during that time but it was due to misinformation. The arms themselves are well built and my wheels are practically dead center but as @Nasty has stated, the ball joints are literal junk.
I stuck up for IHC during that time but it was due to misinformation. The arms themselves are well built and my wheels are practically dead center but as [mention=162984]Nasty[/mention] has stated, the ball joints are literal junk.
Did you remove the kit? If so I will buy it from you just the front arms
Sorry didn’t look through the 212 pages for my answer.
I have a 18 Sierra Denali with the magneride. Thinking about getting the 2/5 maxtrac lowering kit. Anyone have  this installed?  How’s the ride?  Quality of kit?  It’s on sale for $360 right now so kinda questioning it. Never used any of their products.
Really I don’t even want to lower the front. Just want the truck level. The rear is sitting a little over 4” higher then the front.
Edited by Pt187
No. I had my shop put moogs into the lowers. The uppers are off size for any of the moog ball joints but had them put in higher quality upper ball joints. The kit is staying on for now until I decide if I go bags or not. My shop said the geometry of the arms is good but those crap ball joints are a liability.
I have the IHC lower arms if you want those.
How much. I'm not gonna use them. I'm gonna just do some testing and modification to them to see how I can improve them
I'm not using them and don't plan to so $25 plus shipping.  That work for you?
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
