2008 Silverado 2500hd intermittently not starting
greatjay
Hello,
I have a 2008 Chevy Silverado 2500hd. Recently, I've been having a problem intermittently with getting it started (no start no crank). It has happened 3 times, and each time I have had to call AAA. I'm hoping maybe someone out there knows how to fix this. Any advice would be great...
The first time it ever happened, you turned the key and nothing would happen. No crank. It had full electrical power, but I thought I'd jump it anyway. The jump pack had absolutely no effect. Then I thought maybe it was the anti theft. So I locked and unlocked the doors 3 times with the fob. Nothing. Next I thought maybe either the sensor in the gearshift or in the brake pedal. Played with both to no avail. Then I thought maybe it was a contact in the starter. So I had someone tap the starter while I tried the key. Nothing. Finally I ended up having it towed to the Chevy dealer I bought it from. First they said they believed it was a communication problem with the computers, but wasn't exactly sure what was wrong. Later in the day they called and said the fuse box was the culprit, and I needed a new one. I had them put it in, and everything seemed ok.
About a week and a half later, stopped at the store. Went to start the truck to go home, nothing. No crank. Had it towed to my Chevy dealer. They looked at it and said my ignition switch was bad, and replaced it. Everything again seemed fine.
About two weeks later, I went to leave work, turned the key, and once again nothing. I was determined to figure it out this time. So, I played with the gearshift and brake pedal, nothing. I went to the fuse box and pulled each fuse and relay, checked for debris and put them back in. Nothing. So I pulled the fuse box out, cleaned the connectors with contact cleaner, made sure everything was nice and shiny, and popped the fuse box back in. Nothing. Then I thought that maybe if there was a problem with the computers, they needed reset. So I disconnected the battery for two minutes, and then hooked it back up. Nothing. You can hear the relays clicking softly, but it just isn't activating the starter. I tried shaking some wires to try to find bad connections, even tried pushing it a little in neutral. Nothing. When the AAA driver got there, he took a look. He yanked on the wires coming from the battery going towards the starter, and I was able to start the truck right up. I drove it to the dealer anyway, cause I thought maybe the wire needed replaced or tightened.
They told me that the wire was fine. They checked the starter and said it was ok. And they said they really didn't know what the problem was. They checked everything they possibly could think of. They said to bring it back again when it won't start and maybe they can find the problem.
Does anyone have any idea what this is? If it helps, usually when this happens, the first time you try to start it, it will start for like a split second and stall out. From there on it just makes a soft clicking at the relays and won't crank.
I usually do not do a lot of repairs to my truck myself. I like to have the Chevy dealer do it for a few reasons. It's my only car and I can't chance screwing something up and not being able to get to work. And, if something simple ever ended up being a major problem, they could probably handle it way better than I can. They're trained, I'm not. But at this point if anyone has any ideas I'd be willing to try/check them. Any help would be appreciated.
Thanks,
Jay
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
