Not sure, but it comes in the kit, so why not.
Yes, it is. As I recall, the plunger on the solenoid pushes on the new cam arm and allows you to manually unlock with your key. Stock cam arm will not eggage the solenoid.
Correct, mine just takes a little click to the left or right to lock or unlock.
That is correct
I
When I was finished, I found that I couldn't lock the tailgate with the key. After investigating, I found the new C-clip was moving with the key, causing the locking mechanism to flip to unlock when I returned the key to 12 o'clock to remove it.
The fix: I had to remove the C-clip and re-install it so that the mouth of the C-clip was facing "down" towards the hinge point of the tailgate. Originally I had the mouth of the C-clip facing "up." Hope that helps someone on their install.
Thanks again to a great thread.
Im installing mine right now and was having this exact issue. Glad I came to this thread to read through it again.
Alright so what the hell. Im so annoyed right now.
I've tried the biggest brown/yellow with the biggest solid grey.
I've tried the biggest brown/yellow with the biggest grey/green
I've tried a slightly smaller brown/yellow with the biggest solid grey.
I've tried the slightly smaller brown/yellow with the biggest grey/green.
I cannot get this thing to work. the actuator does absolutely squat. NOTHING. What am I doing wrong?
EDIT:
Finally got it working. Screw those little scotchlocks things. No good. I just did a similar connection as Crf450r420 in post #81. I stripped a bit of the wire off and then connected the blue and greens directly. Works like a charm.
Edited by fondupot
Is this possible if there is the linex spray in liner already installed from the factory? I haven't looked yet, but I would think the linex is sprayed over the bolts and I wouldn't be able to remove that tailgate panel.
EDIT: Nevermind, the factory doesn't go over the bolts.
Edited by Dunc
No decent body shop doing bed spray (Line-X, Rhino Liner, etc.) should cover access panel bolts. If they do, refuse the job and make them fix it.
Installed my pop & lock today on my new 2014 GMC Sierra Crew Cab standard box SLT and it went great. Thank you to Motomedic and all who contributed to this thread. It helped a lot!
I decided to go with pressing the unlock on the keyfob twice to unlock the tailgate. Here's the wiring that worked:
- vehicle's fat brown with yellow stripe attached to the green pop & lock wire
- vehicle's fat gray with green stripe attached to the blue pop & lock wire
I rewired mine Saturday to this method, works great. I think the lock will last longer using this method.
Thanks
Here is my video tutorial, enjoy.
Thank you sir and for all the great people here who share their stories with such details. Greatly appreciated.
Got mine installed tonight 1 hour total. Thanks to all who posted made wiring very easy.
Now for the bad. I snapped the black cover that covers the wire bundle. Yeah the pain in the ass one! I have gone through every part diagram on GM Parts direct and can't find the darn thing anywhere. Not the end of the world still snaps on and holds the sill plate fine.
Any help is appreciated to locate this part #
In case this can help someone I'll post some pics from my install. The wires are the thicker ones if there are some the same color. I used my girl's sewing pins to poke into the wire and test before making my final install. I then pull back the insulation and wrap the wires onto the factory wire. Then solder them up before wrapping them with silicone tape and zip ties to make sure it never comes loose.
Thank you - the pics and info were invaluable.
Mine rattles in there like a son of a gun
Is that bolt secured tightly? Both pieces of that cam thingy?
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
