Got it figured out. Was using the wrong grey wire. Nice of them to put 2 grey wires on there
update ...it was the thicker brown and yellow and the thicker grey and green..had a problem with the connection inside the tailgate that was making it not work...also make sure your actuator arm isnt bent..mine was a little tweeked and wasnt fully locking the gate..thanks for all the help guys..fyi my truck is a sle crew cab so that the wires for that...
Just to note my experience, I too had to use the brown/yellow and thicker grey/green. 2015 Silverado 1500 LT.
Mine also wasn't fully locking, it wasn't pushing far enough so I've temporary added zip ties for the arm to hit.
Hello I just installed the pop and lock on my truck everything work except when you lock it with the fob the little plastic arm doesn't come back enough to lock it unlock works fine,anybody else have this happen and how did you fix it,post pcs if possible thanks
The post above yours had the same issue. They used zip ties.
got mine installed today ended using the thicker of the brown/yellow stripe and the gray/green stripe wires while testing i noticed something weird when locked with the door closed window down i was not able to unlock the doors with the button on the door i had to use the key fob this would happen after the interior lights went out and the red dash light was blinking is this some kind of anti theft cause it pretty dumb. i can lock myself in my truck and not be able to use the unlock button ill have to pull the handle twice to get out. i didnt see anything in the manual about this it just seems strange to me.
Quick question -- since this is tied into the door locks does the tailgate lock automatically like the doors when the truck is put into Drive then unlock when you put it in Park?
I have mine set to lock/unlock with the passenger doors, so mine doesn't unlock when I put it in park. It locks when put into drive.
Cool, I discovered mine wasn't locking as well. I attached one tie strap so the head was in the corner of the plastic arm. Just enough room for the lock cylinder pawl to get past it. Thanks for the tip!
I ended up in the same boat. I emailed Pop & Lock asking if there was a fix and they had me send a video of what it was doing, to which they offered exactly zero help as their "tech support" didn't have a fix, and they won't sell any replacement parts. They were more than willing to offer me a whole new unit at full price, however. Needless to say that left a bit of a bad taste in my mouth and I won't be buying anything else from them in the future. That said, the zip tie trick is working for me as well. Sorry for the rant.
  • 4 months later...
Just installed mine today.  Thanks all for the info and zip tie trick. I too broke my driver side wire cover. 25 degree weather and aggressive negotiations with it didn’t mix well.  Lol.
Some super glue and zip ties and we were back in shape
Edited by squeak93
On 1/7/2018 at 1:22 PM, silveradosid said:
I had the same problem with locking what I found was the arm on the handle was binding I loosen the screw a little and now it works fine
Which screw? I have the issue with it periodically not locking as well. About to add the zip tie method myself like others above. Its odd though, if I got back and forth unlock to lock enough, eventually it does lock.
The screw holding the white plastic locking arm.  1/4 turn is probably all it needs, however I found that the zip tie trick helped on top of this.  Mine was the same way where if I locked and unlocked enough it would finally do what it should, however it was more of a hindrance than hitting lock once and knowing it was going to actually lock.
I just installed this power locking tailgate. Is it supposed to work with the drivers door or the passenger doors. I tried 2 different wires and they both only work with one click of the key fob. I wanted to have it open with the second click on the key fob.
I've been thinking about adding this to my 15.  But if the newer model have a factory actuator, can it be added and wired the same as the pop and lock?  This seems it might be a bit more reliable and more positive operation.  Just a thought.  Any one tried it?
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
