Thanks. Do you have a link to the results? I have been looking for data everywhere, I heard that it was good but Blackbear Performance told me that that Airaid Jr had zero impact on performance during their dyno tests of CAIs.
1 hour ago, bsprtsgrp said:
The Dyno results are very good with the stock OEM Airbox with a K&N drop-in filter and the Airaid MIT.
it's not showing the MIT & K&N drop-in data any longer...it's just showing the stock OEM set-up
OK, now I get it, so this is stock filter with Airaid MIT but there used to be with K&N drop-in. Now I understand.
the Air Raid JR works great, the reason there is no improvements is because there is a restrictor panel inside the OEM airbox next to the fender, so airflow will not jump up unless you pop this piece out.
Edited by flyingfool
American Trucks did a video showing the gains from an AirRaid MIT only on a 14 Silverado. Seemed to make a small difference. I am probably going to throw one on and keep my paper filter.
at the 6 minute mark the moron kid, sprays lubricant oil on the MAF sensor. insane... how did they get 20 hp? lol everyones a sales man these days
it isnt 20hp to the wheels it is from the curve gain
45 minutes ago, flyingfool said:
what's curve gain?
He explains it around the 0:45 sec mark of the video. Basically it's the gains in efficiency showing up with better throttle response, better acceleration. Since the top end HP doesnt change much just from the tube, this will be the difference you feel. It is the highlighted area in this picture.
when i get free time I can data log the intake manifold pressure and the MAF sensor, before and after.. with the stock vs the Air aid JR.  vs restrictor panel removed , then swap in a 6.2 TB and 6.2  manifold.  would make for a cool thread here one day
Dyno, otherwise you've got nothing.
There's no indication of what dyno it was, correction factor etc. They fabricated that chart
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
