cool.. look forward to it. I only took a 2 mile drive.. so I really need to put some miles on it before I know for sure how I feel.
I have about 30k on the Volant in my 04 with the donaldson filter. Give it more time. You will love it. I do like that your lids have the little window. Mine does not
I think it's going to be fine. It sure does pull some air. I don't understand why the Airaid system doesn't utilize (pull air from) the factory side fender hole... as well as the bottom. The Volant does both..
the Airaid pulls all of its air from the bottom. Really doesn't make a difference as long as the system gets the volume of air the engine needs.
If the airaid systems have the rubber seal on top, then it seals against the hood once it is shut. I know the K&N systems are like this and work really well at pulling in cooler fresh air. I'm waiting for the K&N to come out. I used to sell all sorts of air intakes and K&N was always my go to. Volants are a nice system too! VaraRam might come out with something. I used their system on my G8 and was a tru ram air setup. Worked awesome!
So I installed the Volant. Open the box, everything packed nicely. Look over directions, not to bad, all black and white and not to much detail. Go through what should be included in the box. I see one thing, only one breather hose. Double check and nope just one long one. I remove the factory system and start install on the Volant. You have to unscrew the filter mounting cup to get the filter out of the intake box before you can start to mountinh the box to the chassis, they don't mention this. Trust me you can't get the filter out without removing the filter mounting cup.... I tried, way to long lol. I see they want to save on shipping space. The holes for mounting located on the bottom of the air box don't line up perfectly, but I get it to work. Pretty simple. Now install the tube, its ok the airaid tube lines up better but it works. Breather hoses needed to be cut by me, and they don't tell you the lengths to cut so you need to eyeball it. Don't cut to short or you'll have kinks in the breather hose. Would of been nice of them to tell you lengths to cut. Install the filter to the filter cup, that was a pain in the ass. I finally used some WD40 to help it slide on. The lid for the box doesn't line up perfectly, but whatever. Over all the fit and finish could be better. They had long enough time to developed a perfect fitting product but they fell short. The filter is nice, heavy, and appears to be of good quality. It sounds good, and produces a mellow, deeper sound then other cone type filters. All in all I like the sound better then the airaid, but airaid def spent more time on fit and finish then Volant did. Quieter sound is what I was going for and the volant with the Donaldson filter accomplished that.
Now what I didn't like compared to the airaid kit. Airaid supplied you with factory OEM breather hose connections, volant does not. Airaid had precut breather hoses and clamps, Volant did not. Airiad directions were more detailed and precisely written, volant not so much.
What I did like was a sealed box, less obnoxious sound, and higher quality filter.
Overall the both have their pro's and con's but I will stick with the volant just because the sound is not as obtrusive within the cab.
Tapatalk via Moto X
Edited by anthony2558
Good review... Yes.. I forgot to mention the thing about the filter and removing the mounting cup first. Don't know why instructions didn't say this.. but I guess after fooling around with it for 10 min, we figured it out.
Instructions need to revised to include this.. and also the thing about cutting the breather hoses.
I put one of those on a truck...two trucks ago. I wouldn't do it again. It made the truck very loud from the engine compartment, and I never did notice a difference in performance or gas mileage.
If those numbers are apples to apples testing with no fudging then that's good. I can't handle the sound though..... sounds like no low flying birds are safe within a half mile of the vehicle.
I typically try to go for an enclosed/sealed air box unit that gets no air from the engine compartment, that is as quiet as possible. Most times I will mod the stock air box with larger fresh air intake holes and change out factory tube from air box to throttle body with something much smoother flowing than the stock intake muffler that comes on these things. I will mod this one within the next week or so, time permitting.
I noticed that to on the front page after I finished everything. Wish I would have taken notice to that prior. Oh well, I cut them pretty close to what the directions had listed.
Sent from my Nexus 5 using Tapatalk
I just installed an Injen cold air intake for my truck. Very easy to install open top but draws from the fender well. The difference in sound from stock to this is night and day when you get on it but it's not abnoxious. Dry filter no oiling and when I read their dyno test they had the highest gains I've seen and if you look closely it's around 90 degrees when they did the dyno. I have not dynoed it but I notice a huge difference in acceleration and response. Best part it was on sale for $240.
Are you guys disconnecting your battery before you install your CAI? I didn't .. maybe that is why my fans came on unexpected. I see where they say to disconnect the battery on the Airaid instruction, but just thought that was just a precaution. Until I read the Volant instructions.. they say do it so the computer can reset or re learn.
Anyway.. I did return the Airaid .. sound was a little too much, in addition I just couldn't get used to the open air design. I really feel like there needs to be cover over it.. even though the hood of the truck serves as a lid.
Just ordered a Volant ... which looks real sweet. We'll see how that goes.
I think a previous poster nailed your issue right on the head by saying that you probably had AC/Defroster on when truck started. I wouldn't put a hole lot of time into worrying about it. You could spend that time much wiser by doing more mods.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
