Not sure how much I can help but here goes. GM service info lists two P/N for this connector 15509841 and 19301820. The first is called "oem" and the second is called "service". Most likely neither come with terminals or wiring. Just bare plastic connector. They list "terminated leads" but don't say male or female. This is GM speak for a terminal with a wire lead. P/N's are
19329204, 19300649 and some locations not serviced. Parts catalog lists connector p/n 19301820 W/O leads. Good Luck
Edited by tbarn
Awesome you are incredibly good at what you do. Wish we had someone like you at my local dealership. So in theory I can take these to my parts dept and give them the numbers and they would be able to look them up? I have put the part numbers in all over the net and getting nothing.
Tbarn,
I just wanted to thank you for your expertise and ability to handle many questions thrown at you. As a former parts man for Chevrolet, I know the ins and outs of someone coming in and asking for that part that's on my buddy's truck! I will do this modification soon and will refer to your advice. Thanks again!
KRDeal
For everyone wondering the difference with the Denali console, I'll bet the difference is it has a DVD player in the back. Hence the different wiring. Console would work, but you would need to order the different end panel for a clean look.
Hey guys,
I had a 2015 loaner for a couple of days and my curiosity got the better of me. I had to see what the new in-dash USB harness looked like, so I popped the glove box out and snapped a few pics. I don't know if the info will be helpful or not, but if someone with a '15 is looking at doing a console swap, this may be a way to get the front USB's working as intended. Also got the actual part number, too.
Here they are:
Edited by 2Speed
I installed my console on Friday and I am very pleased with the results. The only things that don't work are a 12v up front, the three usb's (opted to connect the one's inside the console to keep all the ipod, charging cables hidden) and the light. The rear 12v and all the connections inside the console work, as well as a 12v and the 110v up front.
hello to everyone. i'm new here and it's my first post
i have installed the full console yesterday , took both harness to built a brand new one (I recycled the cloth tape and reused it so the new harness seem coming from factory, it took about 2 hours just for the tape lol but the finish is really OEM looking)
all is working for now except the fronts USB but i will try to make them working,
i'm mechanic for a GM dealer so i will call gm to know if i can get a new programmation for the HMI so both usb should work
i will let you know if it'S work
another way to get both usb socket working is to put a switch ( electronic one) instead a hub but i don'T like this idea, i would have them working without switching anything
i didn't order the top plate yet as i didn't knew wich colors/trim i wanted yet, ( i did my test with a borrowed plate lol as i work at the right place)
all the work was done easy , only the tape parts was handy but the result worth it
Edited by ravageur1972
So I'm getting ready to order console and parts for jet black interior. Are the following all that I need?
23466980-console
22817347-panel
22817349-panel
23466980-console
22817347-panel
22817349-panel
you will need the top of console but you need to choose it carefully if not it won't match your truck ( wood finish, gray, etc etc)
and also i called techlink and tac line and both can't help me with the front usb .........so i decide to use them only for charging .
anyway having 5 usb for music is not usefull............i have 2 under the armrest that is enough
so for those who want all usb working , GM say: you can't have a new reprogrammation for the HMI as your truck didn't had more than 2 usb when it come out from factory
Ok. I'm not sure which to order for top of console? Is this like drink holder space?
the cupholder, and the plate which has the colored trim and the power outlets
I need all 3 of these as well?
another tip is to go at a gm dealer and watch some truck that have the console and when you will see the plate you want, just take the serial number in note and then you can order this plate with the serial number :)
no it is all include in the plate kit and it's about 150$
    daveishi
    daveishi
  • Who's Online   6 Members, 0 Anonymous, 387 Guests (See full list)
