Those look to be all roof consoles not floor consoles. Or maybe I'm reading the descriptions wrong? I'd be willing to make a drive to one of those areas for a floor console at that price!!
I thought the same thing however if you go to the menu there is a separate category for "roof console". Also note that the color is listed as black on many of those and as far as I know the roof consoles do not come in black.
Looks like it didnt link directly to the option I had selected but if you click "select option" you'll find floor consoles
$346 Shipped is a steal for a complete console!
I have to agree! I was planning to buy a black leather jump seat with the lower storage compartment to replace my standard gray one but for just a few dollars more I was able to get this!
Hi there quick question, going to attempt this swap Saturday. For the double cab, do you need to remove any seats or can you muscle the jump seat out and place new center in. (Any tips would be appreciated?
i was wondering the same thing....anyone sucessfully do the swap in a double cab without removing the passenger seat?
Nobody hit the $300.00 buy it now and as of this posting the bid has gone up to $510.00 plus shipping! :crazy:
You need to lossen the 2 rear bolts on the passenger seat to wedge it up to be able to disconnect the connector for the center console, but the passenger seat does not have to be removed, and the jump seat can be removed with the driver and peassenger seats intact.
thanks!
thats crazy!
marv, did you end up getting one?
im doing a center console swap today and will have available a black leather jump seat w/white stitching if anyone is interested...truck has less than 1000 miles....brandy new :)
I have a new z71 with the 40/20/40 leather. I miss the console I had in my last truck, but I'm not ready to install the console in the Z71.
Does GM make any sort of storage caddie that goes on the floor in front of the seats?
ive looked around, but couldnt find anything that i thought would look ok in the truck.,.....there are a couple options that i found but look horrible IMO....i sucked it uo and bought the center console and plan on installing today
That's awesome. Post before and after pics! Let us know how the installation went!
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
