I'm not sure if anyone else picked up the strip lights off of Amazon. They are cheap and shitty, I can't imagine they would last more than 5 minutes in the rain. Don't buy them.
Sent from my SM-G900W8 using Tapatalk
Another buyer of these lights here. Ive also got mine mounted underneath just above the running boards. They are exposed to all weather conditions and so far they have been great! Edited by dbcooper
Well that makes me feel a little better about them, but I still can't say I trust them. that tape on the back would not stick for me at all.
I certainly agree with the tape. I peeled off the stuff that came on mine, and used some 3m red stuff
Edited by dbcooper
FInally got my Rigid DOT fogs installed. Man, if you have big hands I wish you the best of luck. I had one hell of a time installing those lights last night. Very pleased with the output, but damn lol. I had a few choice words every time I skinned another knuckle
The end is wide open, I can't see them lasting. They give off great light, and would be great for in the truck. Try dipping one in some water, let's see how long it lasts.attachicon.gif20151215_162604.jpg
Try using some good silicone on the ends. I bet that will help stop the elements from getting in.
Edited by Rotti54
Put on some Suntek window tint today!! My goal was to only darken the front slightly over the factory 70%. Decided a layer of 50% was the look I wanted. According to the calculations this should put the vlt at 35%. First impressions... I like it a lot. Hopefully my decision doesn't change.
Before
After
Put my white handles back on and vinyl wrapped the door trim, maybe going for a full out colormatch look
0565BEE0-F6CB-49DA-BB03-DAB43026431C_zps
Man I'm lovin that color match tow mirror trim... Nice
Sent from my SG Note 4 on Tapatalk
Before
After
Looks good, I did mine 20% all the way around and over factory.
Added color matched headlight/parking light housings. b32c6a3a239043d4543599a21f999b77.jpg
Sent from my iPhone 6s
Looks great! Where did you get the color matched housings?
Blacked out my bow tie. I have to say something as easy and inexpensive as the plasti dip stuff sure make a difference in the look of the truck.
Looks like the ones you can get from ebay
Sent from my SM-G928V using Tapatalk
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
