Been toying with the idea of going back to chrome / polished wheels so I photoshopped some forces on the truck. What do you guys think of this look?
This is about the biggest thing I've towed to date, with any truck. Supposedly weighed 7200 pounds, towed it pretty damn good. Acceleration was that of my regular trailer which I was surprised. Only towed it about 20 miles total to help out a friend who broke down. Sucked not having tow mirrors though
I finally got around to wrapping my door inserts last night in order to get rid of the wood grain. I think they came out pretty good for my first time using vinyl haha
Note: The vinyl is charcoal/black CF, but for some reason it looks blueish/ silverish when photographed :dunno:
A10805AD-9031-4B49-93CF-2F6A9691F7C2_zps
A7D1EF33-7CAF-4F20-A959-66D178312D1B_zps
  • Like 7
That looks awesome, like it was that way from the start almost..
A nice day to put on a coat of Z8. It's the only product I ever use on all 3 vehicles.
15 minutes if you take a coffee break in the middle.
... And what is Z8.? Thanks in advance.
Sent from my SG Note 4 on Tapatalk
looks good . who makes Z8 , or who sells it ?
Z8 is a Premium spray-on paint sealant. Much more paint protection than a typical detail spray, but not quite as much as a synthetic sealant that is applied with an applicator and then buffed off.
Z8 is made by Zaino. I've been using it for over 15 years. It will make your paint shiny and slick. Spray on, wipe off, done.
http://www.zainostore.com/mm5/merchant.mvc?Screen=PROD&Store_Code=Z&Product_Code=Z-8&Category_Code=shinemaintenance
Detailing "Purists" (I should know, I used to be one) will tell you that you need to clay bar, polish, apply 2 coats of synthetic sealant, then apply Z8 for shine maintenance.
I simply eliminated the first 3 steps. Mine looks as good as theirs and I saved 3 hours in the process. :cheers:
Edited by Luster
LED running board lights I found on ebay. They work awesome.
Where/how did you get the wires from the lights into the cab?
Todd - when I did my recon Big rig running lights the power was to the front of the truck, ran under to lower part of fire wall, then up to fuse block. all wires were warp . hope this helps you .
AMP Running boards - HOW do you guys like them , are they worth the money . would you do it again ????
Yes, yes, and hang on, let me think about it......yes. Get them.
  • Like 3
I don't know, being in Wisconsin I have heard several times they have had issues with them and heavy snow and ice reliability. Not so much not working but burning out motors from having to lift and lower snow and ice build up (though some have said they have gotten stuck). Do some research, heard good things about them down south but up north I would be leery. That is my two cents. (notice the two above who said yes are in Texas).
Tyler
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
