Nice touch, but I could see that getting old very quick. Many times I go outside to my truck to grab something I forgot to find my door is locked. My neighbors would hate me.
Ha ha yes that could happen.
I've done this mod on all my vehicles since I started driving, so I'm used to it and rarely forget to unlock.
This one was by far the most difficult.
Edited by crewl1
You won't see it in the maintenance schedule as technically, GM doesn't use "break-in" fluids as they once did. However, you will find a lot of owners do their first oil change (and other fluids) early just as personal preference. Personally, I don't put a lot of miles per year on my vehicles, so my first oil change was at 3,000 miles (I had my first 4 done at 6 month intervals, then switched to full synthetic, Mobile 1 and it will be one change annually). Now, I should also tell you that my dealer provides the first 4 oil changes during the first two years at whatever interval the customer desires and does not limit it by the OLM percentage.
You will hear as many opinions on this as there are drivers...
With all the bullshit I've been told from my dealer about oil changes I really don't know what or who to believe anymore. They told me to not go by the monitor, to come in at 7000k, and even if I go with fully synthetic oil, still come in at 7000k. I asked what the advantage of having fully synthetic is then, since I've heard you can go almost twice the distance on it, and he just told me longer engine life.
I run Mobil 1 EP (full syn) and change every 7500 miles. I do a lot more towing than most guys here and I'm hard on my truck so she deserves it lol
I removed the rear block as well as the front plastic air dam. Now she sits 38.5" in the rear and 39" in the front
Ummmm ive got 3,000 miles on mine with no "break-in oil change" done. I see no mention in my manual either... should i be concerned here?
I wouldn't. I've done all my oil changes at 5000, including the first one.
Cali leanin...
Cali leanin...
I am from Cali :dunno:
It's not a big lean, just looks like that way in the pictures, in person it's almost dead level.
That cali swag
Cali leanin...
California lean !Cali lift! Cali swag! lol I like it
Are your turn signals switchbacks?
how are they working for you?
I am on the fence between these and smoking mine.
Why not get some clear corners from Klearz and smoke them?
Installed a Truxedo Lo Pro QT tonneau cover today. Really easy install. Took an hour tops. From opening the box to taking the pic. My apologies for the pics. I'm keeping the truck in hibernation over the winter to keep some Wisconsin salt off.
Other completed mod/act are
Line-x platinum bed liner
Weather tech mats
Rust proofing
Undercoating
Fogs on w/ high beams
Tim
adef69963684ef4fe85114acf3483f6d.jpgd07987851eb762974c23124e09ed8168.jpg52025edc5a4db4e6062f6d11b6681fe0.jpge1233fa7b9baf8baeda27b214bbbf48c.jpg
Installed a set of COB LEDs in my interior front footwell areas. Tied in to my dome light circuit so they come on with keyless remote and switch. Also fade out when turned off for a great effect. These lights are awesome. These are the same lights i used as puddle lights over my running boards (u can see those in pic 2) and cost less than $6 per pair shipped!
Smoothed and painted my mirrors and fender plastics. Never again. Lol. Don't want to see another piece of sand paper ever again.
f0c040704d6f49ed45798b1760746a44.jpg88e53b47c325fee911d5e72abed278c1.jpg7dfcafc8074668d4d6bc437430a09bdb.jpgf35ae9d47cb5e0914c6e69f098f276da.jpg
Edited by FastWS6TA
  • Like 6
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
