Took off bull bar mounted led bar behind grille and installed new headlights. Had to order one bolt and nut for the tow hooks.adfc06bb154ad08d6c30f245f380269d.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Edited by wildhunter
look better without bull bar . what size light bar ? more photo's head lights
Will take some tonite the lite bar was a 180w 28inch Cree spot beam I got about four months back off amazon think I paid 43 dollars for it I know it wasn not more than 50. Working on bed lights going to hook to a toggle switch.
Few night shots don't mine the wire under the rails installing a bed rug might have to add some lights if not the wires will be behind the mat.
61e6bfebc623c4ed9b05921e3f4dcd77.jpg971f875bae1e7a025bdc7da57d83d06a.jpg62abbeec9fbac4857e9af4338b53e9d1.jpg
looks good. bed lite switch - a rocker one would be more better ,wouldn't stick out ????
Do you have constant power to the bed lights? If so where did you tap into for power?
Didnt think of a rocker switch was thinking of something that would standout when i install the bed rug. May have to change it out. For power i ran a wire along the frame from the battey with a 5amp fuse it is hidden from eye sight.
Lifted. Zone 4.5"
Fuel coupler 20x9
Cooper discoverer stt pro 295/60r20.
Slight rub in reverse on the black plastic trim on the corner of the wheel well, but a little trimming fixed that.
1efb156b6013cae4d38d0381e82cb150.jpg4af0f3cb5bd1e71feb2f68f56bd0ff87.jpg0eebe933c5d3eb3229bcccf9e8e207dd.jpg419b0ec48b9f3eb6a00fba70170a7845.jpg8a2836085aecec8861aa026da835d719.jpge72028baaafa6ec958e45d637a8f9ec4.jpg
  • Like 9
Lifted. Zone 4.5"
Fuel coupler 20x9
looks good . need BIGGER garage ????
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
