Had a gear swap done today went from 3.42's to 4.10's. Happy with the feel so far, but still awaiting on tune update, and trying to take it easy on break-in
are the new gears Yukons? I'm interested in doing this when I lift my truck. Also, is this something the dealer can flash into the onboard computer or do we have to go aftermarket tuning only? thx
AAM. I believe the only way to update the computer is aftermarket as 4.10's are not a factory option on the 1500's.
Edited by SgtShiv
Added my step bar leds today. Tied them I to the dome lights so they come on anytime the dome lights are one. Works great with the key fob unlock and such.
Edited by mjdxtreme
That is definitely a cool mod.
When I added my hid's I had to shut the exterior lights off so I would not burn out the ballasts with the on off cycling of them. So figured after reading others on adding footwell lighting and assist lighting. Figured it would be the perfect mod for adding light while in dark parking lots and such. Works great and for like $70 bucks and an hour in my garage. They turned out great and put out tons of light.
Edited by mjdxtreme
Very nice... Would love to do that mod. Any chance you can provide a first time truck owner the write up on how to do this.? TIA
Sent from my SGS7
Sent from my SGS7
I cannot take credit for figure this mod out. There are several members who have done similar mods and I used the great info that they provided. Here is a link to where I got some of info to complete.
http://www.gm-trucks.com/forums/topic/172674-footfootwell-lighting-color-match-wiring/
This is just one place. There are several other links as well.
Thanks brother
Sent from my SGS7
Installed Pop & Lock and readjusted tonneau cover, wasn't quite right after bed liner install.
What lights did you use? Looks great!!
I cannot remember the brand. My brother found some on ebay. They were a set of two 5 ft long strip of led lights with a rubberized coating. 3m tapes to hold under the rockers. I can get a closer shot of them if you need me to. We ran the wires through the rubber grommet on the drivers side that the e brake cable goes through. And on the passenger side there is a plastic plug we drilled a small hole in then used silicone to ensure the hole was fully sealed. Snaked the wires under the carpet and behind the dash to the wiring harness that controls the dome lights.
Put her in a ditch over the weekend
bad weekend. are you ok ??
rdnckhntr94
Sorry that happened. Did you shear the bumper? Surprised it would break off like that.
Edit...I see now that the bumper bent and the cover lifted making it look broken off.
Edited by DAY11
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
