You are correct! When removed, it improves offroad handling like you wouldn't believe.
I wouldn't recommend removing it unless you know exactly what you're doing.
thank you . but my truck see more black top these days .
Got the Morimoto Lights in the mail and have been searching all day on how to remove the factory fog lights.....
For those of y'all that have installed Bilstein 5100's in the REAR, did you install piston or body up? The lettering I suppose is to be upright which means piston down. This is how it was on my 5160 series shocks on my 02 on front and rear. Any insight would be great gents!
I'm definitely thinkin body up, piston down. That's the way my fox shocks are installed (as per fox, not just what I decided to do lol)
My understanding is you have to pull the whole bumper off. That's whats kept me for getting new fogs.
I didn't see instructions in the box so checked their website and didn't see anything. Guess I could email them about it
You do not have to pull the bumper off to install the fog lights. There are steel brackets held on by 6 or 7 15mm bolts and you also have to remove the bumper support bracket.
Ya I called them cuz I wanted to ask about rear shocks with reservoirs
Installed OEM mud flaps on the front. Ran out of time for the rears. Figured the rivnut thing would be trouble but not really
Edited by DAY11
I don't know from experience just going by what TheRetroFitSource guy said. If you do figure out how to do it without taking the bumper off please post how you did it.
If you use a quality polishing compound and some elbow grease you can remove 95-99% of the hazing. I recommend Chemical Guys products.
When removing the badging, did you use your fingers to remove the sticky, WD40, or the wheel? If you used the wheel where can I get it what brand and how gently should i use it?
I just removed it with my fingers with some WD40. I have a black truck so I had a few small scratches but they polished up easily.
Installed Recon third brake/cargo light. Waiting for my red smoked tails from Spyder to arrive.
If you are looking to get new headlights to let me know and I'll buy your gmc headlights.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Windows tinted, 3m clear bra on the hood and mirror caps, weathertech tailgate protector.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
