I'm not a lawyer, but, it depends on where you are, and if they want to enforce it. Just so you know, this is no longer a secondary offence. Meaning, for a while now, they can pull you over for tint, points and fines will closely follow, lol...
Had the front windows tinted.
Edited by Daly
I (spray) waxed mine for the first time yesterday.
It's slicker than snot now, I swear I picked up 1 or 2 mpg, lol.
Check out the video of me making my custom Headlights
2014 Silverado 2WT 4.3 V6
Instagram @egroj_legnar
YouTube.com/jorge_dropkick_rangel
Your light setup turned out awesome!. Surprised you don't have the LED bowtie. :D
Only reason why I don't have is cus GM wants my kidney for that bowtie.
Finished up an FXR 3.0 Retrofit with Diode Dynamics Switchback LED's.
The install is a true pain in the neck, but the results are fantastic!
Thinkware users, I have a couple questions about it. I just hooked everything up, having issues, tried to contact Thinkware, but cannot leave s message, mailbox is full...
Can i get more details on how to inhibit DRL
Any pics ? how to do the mod
Thanks
Marc
Envoyé de mon iPad en utilisant Tapatalk
Do a search on it.. there is a thread in here somewhere on it.. just cant find it now... but you pull the driver side fuse panel lid off (between door and dash) then pop off the headlight, 4x4 bezel... unplug the 3 plugs... then you can take the headlight switch apart and there is a small spring inside that you remove..
the spring is what keeps the dial from staying in the OFF position and springs it back to auto... by removing the spring, you are now able to keep the dial in the OFF position, killing the DRLs
Thanks for replying, i'll do a search.
Then if i do so, i can't run with the parking light only.
Am I correct ?
Yes... you can still run parking light only... after removing the spring... your switch now has 4 positions that you can lock it in
OFF (which even from there you can turn on fogs and parking lights)
AUTO
PARKING LIGHTS ON (can run parking lights only or parking/fog)
HEADLIGHTS ON
Am I correct ?
I switched the headlight pin on my truck that has Canadian DRL that cannot be turned off. Now in daylight, the parking lamp comes on when I start the vehicle.
I have the thinkware f770. What problems are you having? Maybe I can help. Maybe I cannot.
Sent from my Pixel XL using Tapatalk
Truck started leaking couple weeks back. Finally brought it into my body shop place. Apparently the glue on the back glass came unglued and formed a nice lil channel for water to get into the cab.
Body shop had replaced the back glass so they're fixing it for me and sending it to get the headliner cleaned
Also installed the pro clip phone holder [emoji16]
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   0 Members, 0 Anonymous, 4,351 Guests (See full list)
