Has anyone bought any of these?
http://www.ebay.com/itm/141685859719
Sent from my SAMSUNG-SM-G935A using Tapatalk
I got something similar through Amazon for less. I saw the ones on eBay but felt more comfortable with Amazon in case I wanted to return them. I have had them on my truck for about a month and half and they are excellent.
https://www.amazon.com/gp/product/B00YI5W3NU/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Newspapers still exist?
For how much longer?
Pics of them installed?
I did about a year ago and ended up throwing them in the trash. I only got the headlight pieces and had them on for a few months but the more I looked at them more they looked hokie. Just my opinion.
Had a Borla XR1 muffler installed, clamped open the flapper, left the resonator intact. Sounds great.
Washed the bugs off it today, and took some measurements. It's 37" at the front and 39.25" in the back, so I'll have a 1" rake after pulling the rear blocks. Also booked the truck in to tint the front windows. And still searching for some OEM 22's.
Edited by Daly
Which mud flaps/splash guards do you have installed?
Can't find the post, but someone wanted pictures of the ProClip holder without the phone inserted. Hopefully they look ok, my camera on my iPhone is one that is plagued with the shaky camera syndrome.
Photo Aug 31, 5 49 33 PM by Jim Fox, on Flickr
Photo Aug 31, 5 49 04 PM by Jim Fox, on Flickr
Thx!!!
Sent from my SM-G955U using Tapatalk
See my vehicle build post. I changed out the red grille that comes with the Rally editions for a gloss black grille. I first planned to change out the lights as well but the ratings for the reasonably priced ones on Amazon were very poor. I was also concerned that the black "glossiness" would match. I took a chance on the Razor trim cover and it matches the grille perfectly.
http://www.gm-trucks.com/forums/topic/203428-uofazcats-victory-red-rally-silverado/?p=2025937
Husky
It came our great man. I'm jealous haha
BG INDUCTION cleaning on FUEL and Air from Throttle plate to Piston Tops! Chucked All 8 plugs.....watch out for #8 it's not a show stopper but does require 2-3 drinks to get in the mood........BG'd the ENGINE for 20minutes and replaced all filters.......and washed!
If anybody cares the plugs in my opinion looked decent and can go 60K...Just remember they are GDI engines so I would advise not going much longer. As it will only speed up the valve and piston top coking etc. These engines require a little more maintenance is all I am saying and staying on top of GDI's are something you will eventually learn either the easy way or hard way. It's more than just oil and changing by the way with GDI. These engines are pretty stout! I like em so far and working on have been pretty much straight forward...........
I mean it's all been straight forward after I removed the God Awful plastic Intake Box contraption that is 3ft by 2ft? Really, stick it on a tree and Shoot that ****ing thing...................
Edited by mookdoc6
Soooo confused....
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
