Painted this up for a good friend. Still hoping to get my truck washed before this long weekend is up.
Alldrivelines.com HD driveshaft. Stock on the left. Hopefully this get rid of the vibration.
Well this happened... so  I washed, clayed and polished my truck.  Like I needed an excuse.
Edited by UofAZCats
  • Confused 1
keep us posted... i still think the torque converter is the problem with vibes , if so you will smoke the trans if it continues, cheaper to install a new TC than a $5000 tranny, i'd put my money on a Circle D converter instead of a new Drive shaft
On 5/19/2020 at 8:54 PM, Crazykid38 said:
Wrapped the wood trim today to match the steering wheel trim and radio bezel. 1e661efac3ba3ac7edbce79a0f08acde.jpg
This looks awesome. What vinyl and color did you use?
Never heard of TC problem.... but I’ll keep that in mind. I will eventually get circle D triple disk. But I’m out of funds right now haha. This supercharge build in this quarantine is draining me.
The vibration I have is from 70-80 ish on WOT. I heard the driveshaft is the problem from a lot of people. Plus.... I need stronger driveshaft anyway. Sooo 2 birds 1 stone kinda situation.
its a major problem on these trucks
12 minutes ago, CajunFries said:
The vibration is 100% gone!!!!!
I wonder if they make one for the  crew cab standard bed all I saw was short bed on there website
Saw this yesterday and thought it looked good. 285/65r20 KO2’s. Not sure what size level. 2.5 or 3.5 likely.
Mine is a crew cab standard bed also. I called and talked to him. I’m lowered 3.5” in the back. Did some basic measurements and was able to get to to me within a week and a half.
Avery Dennison from Amazon. Highly recommend their products and it was a brushed aluminum color. It matched the radio bezel perfect.
K&N
nice, mine has 4/6 drop I book marked the website so I will probably give them a call soon
Nice! Yeah I’m loving it. Tested it out in Mexico on the way home and it was silky smooth alllllllllllll the way up!!!!
K&N
Just ordered some! Thanks for the recommendation ?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
