Modified and painted by machine shop but ugly af I don’t care as long as if works though, I’ll grind and paint it my self when I have time. No more gap tho ?????? fit is good just ugly looking ?
Edited by Frankielozano214
Finally started mods/accessories and picked up a bed mat from the dealership. Used my points so it came out super cheap. I already like this so much more than the bed liner in my 2015.
  • Like 3
Great choice, I have the same mat.
It started in my 14, took it with me to my 16, and now lives in my 18. They last forever.
4 hours ago, HoosierZ said:
Repainted my bumper skid plate frame and polished the plate
That looks sharp! Really like the color matched Z71 emblem (know that was not the purpose of your post)!
Installed the Borla ATAK duel side exit exhaust with black chrome tips. Definitely makes it look and sound a lot better. Washed her for the first time this spring after the install.
I painted my driveshaft.
Also I got a Superchips Flashpaq F5 tuner.
Still need to get it 100% dialed in but it does as advertised.
Here she is lurking by the lake this morning.b5e4e3e4ca80388c1a8f1a5885a584bb.jpg
Sent from my Pixel 3 using Tapatalk
Still doing. Fixing the shitty bumper gap the truck has had since I bought it.
18 hours ago, kwOH said:
Got a detail, a couple days ago.
564f09c532cff10a6cbf2e139f1d1a67.jpg45f6a5474393c765501471c74b81d2b8.jpg8af01c6938413276424578bbfaa50446.jpg
Looks like you built a new fence too! hahaha very nice shine alright.
Sanitary setup
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
