Combined 100k & 150 k service
Powerstop pads & rotors all around
New plugs & wires
Flush cooling system
Flush brake system
Flush Tranny
Flush Diff
Also got the waste gate (my version of exhaust cutout) opening at 8PSI. Did a little quick pull. Its a lot raspier than I expected. The boost did dropped a little bit from what I can tell on the gauge, about 0.5-1psi.
That's a sweet setup.
My first Duramax twenty years ago scared the shitte out of me when the wastegate opened the first time I poured the coal to it.
Sent from my Pixel 3 using Tapatalk
I was under the impression that the wastegate relieves pressure when there is too much boost to prevent a big kaboom.
Someone correct me if I'm wrong.
Took her out for alil, crazy how quick the weather changed!!!
I told you to get your longjohns ready.
  • Haha 2
You don't see this often.
What do they do ? Salt the piss out it?
The can't have too many plows in Dallas.4e0be8f4b1b01e63632518e171d2260b.jpg
Yup been few years since we had this much snow ❄️ ⛄️
why would opening a cutout make your boost go down
Wastegate is usually use to regular boost for turbo system.... I’m actually running a supercharger... which doesn’t use wastegate to regular boost. BUTTTT I’m running an aftermarket 3.5” cat and planning to up my power to about 750-800HP.... and 3.5” exhaust is too restrictive in my opinion for that power level... let alone the cat... it’ll be soooo restrictive with the cat. Soooooo I added a wastegate to relieve exhaust pressure right before the cat.
The boost (on the gauge which is tapped into the intake runner) goes down because it’s more free flowing. The easier the exhaust move, the less pressure will be in the intake side. But that doesn’t mean I’m losing HP... if anything I’m making more power.
It’s like adding a better flowing cam. Swapping a cam out will definitely drop my boost shown on the gauge. But without swapping my pullies, I will probably make another 50-75HP with boost gauge showing 2-4 PSI less.
Hope that clears it up. I know I’m not the best at explaining things. Sometime I even confuse people more haha.
That is correct if I’m running a turbo. I added a wastegate using it more like a cutout and relieves exhaust “back pressure”.
here in Central California it's mid 60's low 70's the rest of ya'll freezing except Florida
lol, ya I wish I could leave this place but it's warm enough usually and I make a living otherwise I would be in Florida (maybe), Oregon is not to bad but no work there
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
