hit the beach this weekend~.. Port A.. .. truck needs a wash.. man that sand is a pain!...
I see you caught "crabs " while on vacation ....nice
Sand is a pain, heading to Bar Harbor/ Acadia in 2 weeks , not looking forward to the clean up !
not much better than that view
Got all your holes plugged! Looks good
and gained 1mpg somehow. haha
Received and installed my Husky Gearbox in the mail today. Finally able to cart around a few necessities in the back
Best of all it was FREE since it was part of a Bakflip promo they had going when I bought my Bak X2!56b0f21c0a7e337e8f4d050fc87b8d95.jpgd784571e29720decc0c1c6a3d9870239.jpg
Sent from my SM-G935V using Tapatalk
  • Like 6
Installed my AFE CAI. Love the growl!!!
Edited by acc412
Well no going back now! 6" BDS lift, FOX 2.5 DSC Coilover fronts, Cognito UCA's, FOX 2.0 Performance DSC Reservoir rears, BDS Glide Springs, 20x12 Rockstar 3's, Cooper STT Pro 35/12.5 20's and regeared to 4.10
67B431D4-12B7-4FB8-98F2-62FBD50566E3_zps
3490BFA8-4E5D-4C8D-AAE2-3A56C57F19A6_zps
520E35FD-9F88-4CF6-9CFC-5526844356CF_zps
Edited by JayBentBadger
  • Like 11
Used the $100 Online Bonus Coupon to pick me up a truck bed web and Center Console organizer, out the door for $10 with the coupon, not bad!
Used the cargo net on my trip to the Port A, worked great!!!! Didn't help me catch and fish though lole61a672a6ade03ec40c445aa95de6620.jpg
Well no going back now! 6" BDS lift, FOX 2.5 DSC Coilover fronts, Cognito UCA's, FOX Performance 2.5 DSC Reservoir rears, BDS Glide Springs, 20x12 Rockstar 3's, Cooper STT Pro 35/12.5 20's
wow!!! beautiful truck! :drool:
Thanks! It was a lot of work. But well worth it! All done by myself and a buddy of mine. Rides like a champ!
Truck looks great! What hood protector is that?
Thanks! It's an AVS Aeroskin. They are actually pretty cheap. Think I paid $45 for it. I like it compared to a traditional bug guard.
Went and got my first oil change, after hitting a little over 1K/miles.. Service guy wanted me to be sure I wanted the first oil change at 1K :D
Also got the "Steering assist is reduced" issue cleared. Was getting it with every start up, after using the Range AFM Disable for about a week or so. Service guy stated the '17 are finicky with electronic add on interfering with the bus communication. They noted I had added a camera system, foot-well lights, custom exhaust. But took care of me under warranty. He wasn't too worries since the CEL wasn't lit, just a warning message. Great service department so far.
Sent from my SM-T810 using Tapatalk
Congratulations you've found a service manager who isn't miserable and out to spread his misery to others. He knows what items he can charge off to GM with no concerns, and what items GM can potentially ask to audit him on (usually mechanical things that can be taken apart by engineers). Be polite and you should be taken care of relatively well. Throw them a bone and bring it in for a service occasionally even if you can easily do it in your driveway. The few extra dollars you'll spend can help foster that relationship.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
