Thanks! It was a lot of work. But well worth it! All done by myself and a buddy of mine. Rides like a champ!
How much did the set up cost you besides tires and wheels? Thinking about doing a 6" BDS but not sure if the extra ~$1400 is worth it for the Fox coilovers. Truck is mostly a street truck anyways
Sent from my SM-N920V using Tapatalk
Congratulations you've found a service manager who isn't miserable and out to spread his misery to others. He knows what items he can charge off to GM with no concerns, and what items GM can potentially ask to audit him on (usually mechanical things that can be taken apart by engineers). Be polite and you should be taken care of relatively well. Throw them a bone and bring it in for a service occasionally even if you can easily do it in your driveway. The few extra dollars you'll spend can help foster that relationship.
Yup, they are about 35-40/min drive away from me, but I like their service.
They forgot to install my bed LED when I first got my truck, they had me come back at my convenience and filled my tank. Gave me deader cost on line-x, honored the $100 coupon 2 months after I already purchased the truck. I don't mind driving that far for good service.
Both times I've brought my truck in, I've been complemented on my exhaust and asked what type muffler I have.. :D
Sent from my XT1575 using Tapatalk
Edited by jpinoy
  • Like 6
Got the rest of the interior dipped.
nice job! looks great
  • Like 3
Installed my nerf bars!
Just tried to do what you did and my metal clips fall behind the door panel lol.
It was a pain the a**
Tell me about it lol, I did one half fast and said forget it. Ordered some new clips
I paid $4350 For the lift, Coilovers, rear springs, and the rear reservoir shocks. The tricky part was the back finding a reservoir rear for it. FOX doesn't have one for a 6" lift for a 1500. So I am using a 2500 4-6" lift reservoir with the DSC controls. It rides really good. I thought it would be stiff between it and the spring but it isn't at all. My only gripe would be the front Coilovers. They are a pita to adjust. They should be preload adjustable like the instructions say but they aren't. In fact I couldn't get them to adjust at all even in a spring compressor and the spanner wrench. I need to go up just a little. I have some rubbing on the backside of the front. I'm gonna check with a shop on Monday to see what they will charge to adjust them up a 1/2". Hope that fixes the issue.
Did you loosen the little Allen screw in the preload ring?
Yeah it was loose. I don't know what the deal is.
Got the rest of the interior dipped. 423e80fcc1defea9e259d537d3619079.jpgc9bd3e6377fa8a4ad20edd83712e7141.jpgc19cd84c623361b4fc4d0cfca4acc85b.jpg
That looks sick!! How much did all the interior pieces cost
My boy from high school owns the company so I don't pay full price. I'll ballpark ~$200-250 for all them. His IG name is Maine Coast Customs and same for website. His name is Jeff...Tell him Gary sent you.
looks good. How do you like them ? You think they will work GM mug flaps ? DO you have any better side view photo , to see if they will work ??? Thanks
Edited by tahoe08
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
