Got the 2.0s installed on all 4 corners finally. I would definitely suggest these as everyone says. Tighter turns, planted, takes bumps with ease, performs great off road when needed. Best under $1k suspension mod I've ever gotten.
love this upgrade....this just might be my next mod.
Hit some road debris. Ripped off the plastic deflector in front of the left rear tire.
I think it's #7 on the diagram but that's for an 8ft box. I have the 5.8 so I'm not sure.
http://www.gmpartsdirect.com/auto-parts/2015/chevrolet/silverado-1500/lt-trim/5-3l-v8-gas-engine/body-cat/exterior-trim-pick-up-box-scat
http://imgur.com/TscuIm9
Edited by tootall87
the diagram shows that part #8 is for a 5'8" box, I think you scrolled down to far, that's all...
8 22801024 / Protector, LEFT
5.8 FT BOX, SIDE PANEL, REAR, CHEVROLET
$14.54
Edited by 6.2Midnight
$14.54
My original was a typo. I think it's part #7,the deflector. Which the one I see is for the 8ft. I would imagine they are the same part.
so you are looking for the part that looks like a mud flap, but mounts in font of the wheel, correct?
Black bowtie install! Much nicer. Rear one sucked even with heat gun and in my 105 degree garage lol
Also put some slim black plate frames on but need to find black screws, anyone have a source?
eb4671cb3028a561d88ae95c8cde1a1b.png987d24dc25cea2a759a2a99fd61102d5.jpge862f03e09e326563bb80d741d612539.jpg
Not sure if I like blue or black GMC logo,
My first time trying vinyl, did meh.
Black license caps -check local parts store (pep-boys ) they just snap on.
:thumbs::thumbs:
Freshened up the bed....
  • Like 4
Got bored with the black lugs I had on the truck. Got some new ones to change things up a bit. These are the 2 piece version from VMS Racing.
AD726497-7B3B-4343-BB1C-AF17EC2A1334_zps
Edited by 05cyclone
I didn't take pics, but I did install some sundown 2.75" speakers in my dash location and I put dynamat under that panel while I was in there. Of course I soldered the connections and used shrink tubing so I wouldn't have to go in there again. They are powered by the alpine ktp 445u I installed in the under jump seat storage. They sound pretty good. I definitely hear more detail.
No more stereo upgrades for me till I can afford to drop $4-500 on a nice set of components for the front doors.
2014 Silverado Z71
2014 Silverado Z71
how hard was it getting access?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
