attachicon.gifWP_20170626_22_58_29_Rich.jpgattachicon.gifWP_20170626_23_59_39_Rich.jpgattachicon.gifWP_20170627_02_19_51_Rich.jpg
Left work a little early and got it done last night. It took me a lot longer because I was fighting with that lower chrome skid plate. Even after removed the 10 7mm bolts I couldnt get it to completly clip in, GRRR.
The fogs went easy, just lots of bolts, but all easy to access.
A little blue for my taste, I looked it up and those fogs are 5500k. I have the HIDs from TRS and they are 5500k. Is the picture just making it look bluer than it is?
Is that the light up GM bowtie?
Edited by jrob56
It is the light up bowtie. It's more blue than I expected, almost the same color as the bowtie. The box says 5500k, I might ask the retrofit source about this. What I know for sure is I need to do something with the headlights. Edited by Donolie
I got their HID kit for the Silveardo Projectors and very good quality. Worth the money. I followed Fondupot's walk through vid on youtube to get an idea how I wanted to run them and them and went from there.
Anyone do a muffler delete and cause problems with the way the truck runs, sounds, or performs?
I have a 2017 Silverado 5.3L and don't wanna ruin my truck
Put the city wheels and tires on. Doing too many pavement miles!5a55e5fc7a28756608a91f8cb3931fa8.jpg
Sent from my LG-H812 using Tapatalk
Apparently I don't know how to post pics.
Mine look purple when they first come on until they heat up and then look pretty close to my HIDs. I don't feel like they do a good job as far as a fog light though. More of just an aesthetic type of thing
I decided to take the truck in a different direction from the Bilstein 5100's and ordered some Fox 2.5 extended travel dsc coilovers with matching shocks for the rear. I couldn't have those on stock control arms so I also ordered some Dirt King uniball mid travel control arms and long travel shackles. I can't wait to put these on!
Been on the forum for about a year now and this is my first time posting. So here's my truck: 2015 5.3 2.25 Pro Comp leveling kit, Lund Hard/Soft tonneau cover, Banks CAI, Linex bed liner. Plan on adding bigger tires and powder coating the wheels black and lighting in the bed. I'm always looking for suggestions.
Edited by Hesterpj
Been on the forum for about a year now and this is my first time posting. So here's my truck: 2015 5.3 2.25 Pro Comp leveling kit, Leer Hard/Soft tonneau cover, Banks CAI. Plan on adding bigger tires and powder coating the wheels black and lighting in the bed. I'm always looking for suggestions.
I like the hood deflector, what brand?
Welcome, and do your self a favor, weld the hood shut, put a very low limit on your Credit Card, and just plain ole' enjoy your truck! LOL
  • Like 5
heh... i was going to say that it looks like things are going 'down hill' since swapping out tires!
:ughdance:
AVS I believe I picked it up from Oreilly
:ughdance:
I was thinking the same thing! Picture taken in your home town.
Blackout your bowtie... :)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
