The first day I removed the air damn a buddy at work and he pointed out two tabs are visible from the side almost imminently. I did mean the smaller chrome piece by the tow hooks. It's not terrible, one 7mm bolt on the top was tough, but I just can't get the tabs on the top to clip in. I'm going to try this week when I get my Morimoto fog lights with the bumper removed.
I was hoping no one would notice and so far so good. Is that the one piece black led fog lights? Eyeing those myself.
Had a 500 mile weekend and went fishing among other things.
Found out my new Access Tonneau is NOT dust or water tight. At all. Gonna need to get some gaskets soon.
  • Like 3
Just so you know, the bumper doesn't have to be taken all the way off to swap the fogs out. Just takes about 10 bolts on each side and the fog bracket comes out.
I figured I would also try and install the front chrome lower skid plate. I didn't have any luck getting the new one to clip in.
I went ahead and plasti dipped my Silverado emblems and bowties today. Loving how easy it is to use this plasti dip!!
Any tricks to doing this? I want to do the same on my chrome Silverado & LT badges....
looks good. how many coats ?? what about car wash (brushes ) ??
Car washes (touchless) do not seem to hurt the Plasti Dip. I have been through numerous, heavy rain, etc. and it has held up awesome on my truck. I did at least 6 coats, lightly applied, to built it up. Don't just cake it on in one thick spray. I wash my truck by hand and a wash mitt doesn't hurt it either. I'm sure if you took a rough brush to it, over time, it would come off though.
I took my time in prepping, but that being said, you can spray plasti dip all over your door and it'll peel off easily (unlike paint). I just found doing a good job on taping off my bowtie on the front and rear made things easiest. The emblems on the door I did too (before completely removing them) and you can't tape in as fine detail as you can with the bowties. Just tape off what you can, apply all your coats (6-8 IMO), and let it dry. Once it dries just take your time peeling it off, and the edges of the lettering will cut it cleanly. You can use a toothpick to get into the tiny awkward grooves to get you started as well.
Thank you sir!
Anyone use the "Glossifier" on the black?
post-157509-0-38729600-1498577056_thumb.jpgpost-157509-0-03092500-1498577058_thumb.jpgpost-157509-0-05255500-1498577059_thumb.jpg
Left work a little early and got it done last night. It took me a lot longer because I was fighting with that lower chrome skid plate. Even after removed the 10 7mm bolts I couldnt get it to completly clip in, GRRR.
The fogs went easy, just lots of bolts, but all easy to access.
Post some pics when you get them on. Curious to see how they look.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
