Finally got my Method NV's installed. I got a good deal on CL for them in Dec, but just never got around to getting them put on. I went with the KO2 and love the look. Lost a little power to the extra rotating mass but it was less than I had feared. Rides better than my stock 20s did so worth the trade off!
17x8.5 285/70/17
Edited by jrob56
17x8.5 285/70/17
Your truck looks fantastic! This is a tough, solid and practical look without going to extremes. Nicely done!
Added some new scratches and put a few more notches on her belt. Broke 2 ropes.
6 trucks stuck. I really need a winch
e9a3b092407d26654cd9e78a7302cae6.jpg5575f3fad9623844ce2fba24db31c348.jpg63bb398ca92c809d412772f9a5c0a04e.jpg
Sent from my Pixel XL using Tapatalk
Edited by smcgillis10
Thank you! I was worried all the chrome would make the black wheels look out of place but think it worked out.
You can buy one at Costco for a good price
Plus the new bumper or winch mount...
It's not that hard. You don't need a new bumper, but if you have any other questions please hesitate to ask...
That looks like a HD, but I presume it could be done on a 1500, too, provided a front plate isn't needed.
Sent from my iPhone using Tapatalk[/quote3fbfbf319850205c5c01b2ba77d29560.png
Edited by SuperSierra
Removed the Z71 decal and finally got my leveling kit on.
thats what I'm talkin bout!!
Just put on 35" tires, until I put on my BL. Going with 37" in a few months. Put on my Diablo Trinity to addition setup.
17x8.5 285/70/17
Looks sharp. Did you bend the tabs up from where the front air damn was bolted? I have a Reg Cab short bed with fox 2.0 2'' lift and I can see the tabs but didn't notice them in your pictures. Did you install that front lower skid plate? I struggled with mine, still haven't been able to get all the clips installed.
Edited by Donolie
Thank you! I didnt bend the tabs actually, I thought about it but only really visible from certain angles. As for the skid plate, do you mean the the front lower chrome one in middle, below tow hooks? It was already on the truck, came stock with it. I can imagine it is not easy to remove or install one. Probably easier to pull bumper and do it and put the bumper back.
I want to do a 2016 front end conversion at some point so I can put the real skid plate on that goes from the bumper back to the cross member.
Edited by jrob56
The first day I removed the air damn a buddy at work and he pointed out two tabs are visible from the side almost imminently. I did mean the smaller chrome piece by the tow hooks. It's not terrible, one 7mm bolt on the top was tough, but I just can't get the tabs on the top to clip in. I'm going to try this week when I get my Morimoto fog lights with the bumper removed.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
