You're entitled to your opinion.. but don't forget a big part of this forum is customizing/modifying owner's trucks exactly how they want them.
If you have HIDs in anything but the Sierra SLT or Denali, permanently disabling DRL's is highly recommended. Using the knob to kill them often means a quick start up then switched off, which is bad for the HIDs.
In my truck the Auto DRL's only come on when put into gear so how would that put a load on the hid when starting?
I don't mean to offend anyone but just don't see the point in adding a feature that already comes with the vehicle?
not starting a heated debate just asking questions..
Edited by scoobyd3w
I gotcha. I think it just comes down to convenience. A lot of the auto features on the truck aren't necessary and could easily be done manually but we still like them automatic. With DRL's, members just want the choice whether or not to have them auto on.
FYI I can program those out of the BCM.
I bet it's not cheap and you'll need my ecu?
Im curious to know what hardware and software you're using to program.
I wonder how difficult it would be to disassemble the headlight switch and remove the spring feature that prevents leaving it in the OFF position?
You lose the auto on feature because your essentially turning off the light system.
I think my 99 1/2 GMT800 had a position for OFF. If so, it'd be interesting to see if they are interchangeable.
Well if your like me and the truck is parked in the garage all the time then it would be a benefit as I have HID's as it dark enough for it to trip the headlight sensor to make it think it is dark out. I just leave them on when it is parked in the garage, but when it sits out I turn them off.....when I remember to.
turning the headlamp knob to the far left will cancel all running lights (headlamps included) when desired. of course you likely knew that.
there are times when I turn mine off but seldom, just too easy to drive as designed and live with it IMO. after all, its likely only you that will be aware of them being turned off or even disabled.
Anyone ever figure how to disable DRL's? Does a tech have to do it through BCM and will they do it? Thanks
A tech can't do it but my company can through custom bcm programming.
If G (wire) in the headlight plug runs the DRLs, couldn't you install a diode in that wire to render them off all the time..........or (cut the wire and tape it up, if you desire)....?
Also, the wiring manual shows G to be the wire on both plugs (right/left)....
Edited by flyin99
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
