Fitbit?
Chris
Anybody using one? I got one today. Like it so far
I have had one for over a year. Def helped me get into my goal weight. Pushes a guy to get enough cardio in each day.
  • 3 years later...
Old topic I know but I was thinking about starting the topic myself, so I figured that I may as well use this one that I found thru using the search function. :noway: I've had one for about 2 years. If you have one and you'd like to join me in some challenges either leave me your email address here or in PM. :thumbs:
  • GPGuy featured and unfeatured this topic
  • 1 year later...
I thought most phones measured steps, my old iPhone 5 does. Anyhow tracking steps does drive you to be more active.
I been using one for about 1.5 yrs., fitbit charge2  I turned off the notifications, was getting to much spam.  They are worse then onstar though, they can track your whereabouts.
Cardiologist recommends minimum 7,000 steps/day, 10,000 optimum
If anyone has an Ionic and uses game golf post up. Mine is being shit and Fitbit nor game golf can figure it out
Sent from my Pixel 3 XL using Tapatalk
I got an Apple Watch to help do fitness tracking, as well as enable me to not have to fish my phone out of my pocket all the time to see who called/text/emailed me while working, and it definitely helps me, particularly during the winter, when I do snow removal, as during "snow days" it's no problem getting exercise in, but other days, I would tend to stay inside or work on the equipment.  I find going and closing the rings on it every day fairly simple and straightforward, and doing it every day helped me not gain the 10 lbs or so I normally do over the winter.  It isn't perfect, as sometimes the watch doesn't seem to track my exercise while I'm doing it(as in, I tell my watch I'm going for a walk, actually go out walking for 30 minutes, and it will say I only exercised for 10 or 15 minutes).  It doesn't happen alot, but often enough to be annoying when trying to get awards for doing a perfect week or perfect month or make your monthly goals.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
