Anybody have a picture of a 14 denali with trail graps? Having a hard time deciding between those and ridge grapps
6” on 35s. Fuel couplers -12 offset with the tinted spokes. Looks great with the brown matches well!
Looks good, I love that color.
Shakey
What is everyone's thoughts on this wheel?]
Probably look good on a lowered truck. Just my opinion.
I should of mentioned my truck is lowered 3/6
I thought it was after I sent the message. I looked at your screen name and then realized. Lol
20x12 -51 vision rockers on 33x12.50 Federal Couragia Mt
3 inch Motofab Leveling Kit stock blocks in the rear
It rubs so bad but did a NorCal mod on one side and I ran out of daylight gotta do the other side tomorrow [emoji1751]‍[emoji3603] but after the NorCal it doesn’t rub at all
600384bd00c129da1a90bb86f4fc0c0f.jpge948d812ef17e4db481d69392ecdfb23.jpg14e27716156b48a15bf48e3d8c128750.jpg
How do you think some 35s would be with that same lift and width and offset? Im currently running 34x9.5 i think. Thanks in advance! Truck looks really good man!! 540ed2a7de684b871c61406fda818d6f.jpg
1 hour ago, 14cris said:
That truck would look so good if only the tires fit on the wheels....
If only..........
No way possible I got a 3 Inch Motofab and with 33s it tunes so bad it ripping my plastic fender thingy and then when I did the NorCal it’s doesn’t rub at all but it is stupid close you would need like a 6 inch lift or you wouldn’t be able to turn at all it’s the offset and the 12 wides that make it hard to fit
If only..........
Talks the guy with some FUGLY black over played wheels lol
Dude your tires are oversized for your wheels so you’re in the same boat as me, hell i see that you cut ALOT more bumper and valance than i did
I wouldnt be talking about good looking trucks buddy [emoji23]
Looks aside as everyone has their own opinion, but what was your reasoning for going with such a narrow tire compared to the rims? I've read horror stories of safety issues when your tire is too narrow for the rims, so I'm just curious on your thought process
    • I really appreciate the response.  I guess I was confused about torque angle vs torque angle yield.  The individual bolts don't have a warning on reuse but the part number for the LCA nuts does.   Regarding the purpose of the moog grease fittings on their bolts .. Guessing to reduce possibility of corrosion locking the cams or seizing to the bushing inserts.
    • The top speed is software limited, I don't think there's a way to change it without de-doing the whole truck. If you can get a CAN log per my above post we can try seeing if there's anything obvious going on. What happens when you plug the truck in to charge it, does it ever fully charge up or does it stay at low battery %?
    • The LCA bolts are NOT a one time use fastener.  GM does not have them called out as such at all.   They are torque plus degree, but not a one time use TTY.  Nowhere in the service manual does it call out for replacing the LCA bolts for being one time use.  The factory spec would apply to the Moog bolts as well.    I see two things different.  The Moog bolts are greaseable (which I see no point in) and they don't have one of the washers welded to the bolt like the factory bolts, so they can be used in all 4 positions.      Think about it.  The LCA bolts are now the alignment adjustment point, instead of the UCA bolts like the prior generation.  A bolt that is meant to be adjusted for alignment...would it make sense to make it a one time use component?  How would you get an alignment done in the first place?  You couldn't.       Also.  What TSB exactly?  There is no TSB that I see for 2019-2026 for over-torquing LCA bolts.  There was a PI, PIT5533C, but that covered 2014-2018 body trucks for re-torquing LCA mounting bolts.  But those trucks to a 2019-2026?  Not the same, so PIT5533C does not apply.
    • Nice looking setup!  Is this the kit you got?  If so 211 is a great deal!  https://accessories.chevrolet.com/product/trailering-camera-system-86584184   My TT came with a wireless rear camera but it only works on an app or a separate screen they sell so I've decide it's not worth the hassle since it keeps disconnecting and with wireless android auto it's a hassle trying to connect my phone to it.  So I've been thinking about adding the GM camera so it's integrated into the rest of the camera views.   I also found this one which seems to be a different PN & retail price that explicitly states the invisible trailer view https://www.shopchevyparts.com/chevrolet/2024/silverado-2500-hd/electronics/85825715-silverado-2500-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92326971.html?sort=2a
