On 6/29/2020 at 8:22 AM, Codman67 said:
That’s the size I’m lookin for looks good how’s the ride never had BFGoodrich before I have the 285/55/20 Hankooks that came with mine.
Ride is pretty good for an all-terrain type tire.  Rear end skips around occasionally when going though thru sharp mid-corner bumps.  Not sure if that's the tires or the suspension though.
13 hours ago, NITTY said:
Close up
Looks really good, how noisy are they at freeway speeds?
I’ve never had aggressive tires before so that’s hard for me to answer.  They definitely have a howl to them but it’s just my weekend ride so it doesn’t bother me.
Got it, thanks for the reply. It will help me with my decision on new tires.
On 7/20/2020 at 11:48 AM, bugzz2010 said:
2016 Silverado 1500 4x4  2" Level, Air Bags in rear and Monroe Load Lifters
285/65/18 Nitto Terra Grapplers on 18" Tahoe Stocks
Good looking truck, where did you get the 4X4 badges from? They are pretty cool looking.
GM Replica wheels 22x9 with Nitto Ridge Grapplers 305-45-22.  ReadyLift 2.25" front level, replaced rear 1" block with 2.25".  No rubbing.
Edited by Luster
  • Like 4
2.5 motofab up front. Back lifted 3/4 in. Factory 22s with Factory size tires for now. Will have 33s next year hopefully.
  • Like 3
Looks great man! Hey, where you been?
That color is popping!!! Love this truck but I miss the sanoma red on my '14!
I love the color I try to clean this truck whenever I can. Its amazing gleaming in the sun.
  • 3 weeks later...
I only trimmed the fender liners! I took out quite a bit but now they fit no rubbing with normal driving on the street and in parking lots. Even in reverse full lock, no rub.
I don't do much off roading but they would rub most likely.
Sent from my Pixel 2 XL using Tapatalk
Been a little while since you posted this. How you like the set up? No major rubbing?
Sent from my SM-G892A using Tapatalk
Yea Im loving it man. Only time it rubs is when I back out of the driveway and its at like halfway turned. Its rubbing on the plastic cap on the cab corner. Its very minor and I dont intend on doing anymore trimming. If i turn it full lock it moves past and doesnt rub.
[mention=210948]IronVilkas[/mention] I'm running 275/65/20 right now and love the extra height, but the Nitto G2s are almost done after 70k miles and I want to go with something wider while keeping the height. The setup you did looks great and is probably the tallest tire you can fit with a level.
I need to change wheels anyway, these came with the truck, 20x8.5 +35, they keep the tire tucked pretty far with the offset.d124cdd4effedcde865209c6575c75b7.jpge0d7d0a709f769317529c38238689c29.jpg
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,404 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
