Post up some pics when you get the tires on!
Just got the Toyo MTs on. b25e0a4d09ef726cfac5b6528e995362.jpged1eb420cb2b120b7e0edac30530ffa9.jpg
Sent from my Pixel 2 XL using Tapatalk
Looks great. How much did you have to trim? 285/75 right?
Thanks, I haven't trimmed yet. They are 285/75-17 on 17x8.5 0 methods. They rub right at full lock on the liners. I'm thinking an inch or so and they will fit nice
So no metal trimming? I think those are the perfect size if you don’t have to trim any metal!
I only trimmed the fender liners! I took out quite a bit but now they fit no rubbing with normal driving on the street and in parking lots. Even in reverse full lock, no rub.
I don't do much off roading but they would rub most likely.
My 2014 Silverado LT CrewCab
setup is 9” McGaughy lift with the rear add a leaf
wheel setup is 24x14 with 37 13.5 24 OFFSET 76 had to trim bumper and lower valance still rubs a little so I’ll probably do some trimming next weekend my self when I installed my new exhaust
  • Like 3
2018 Silverado Crew standard bed.
5.3 6spd 3.42 Borla S type catback exhaust. Superchips Flashpaq F5 tuner. Running 92 octane tune.
9" McGaughys lift w/add a leafs and 1" lift shackles.
Kryptonite UCA's.
37x12.50x20 Nitto Ridge Grapplers. Scorpion SC29 Chrome 20x10 -19
66" to top of tailgate3ca0beaa2b42fc9c23fe2153f49c6a3d.jpgac710df0206851c33e3727350890e648.jpg35a00ab803a57eaad35ba92056060451.jpg1e9e98afb08fe5736e011cf0ee643215.jpg32541b1508112644b80a50ce798273f3.jpg
Sent from my Pixel 3 using Tapatalk
  • Like 5
2" level, 18" KMC XD Hoss II wrapped in 275/70/18 Goodyear Wrangler UltraTerrains
Edited by 16silverado35
On 4/30/2018 at 11:45 AM, scott.moody.9401 said:
OEWheelsLLC CV98 20 x 9, Michelin Defender stock size4b471d2e276bbd5d879a1a878903b591.jpg
Sent from my SM-T817V using Tapatalk
Are those 275/55/20 how they holding up for you ride,comfort etc
On 1/5/2018 at 4:30 PM, steve76t said:
2" Rough Country level kit and 285/55r20 BFG KO2s.
That’s the size I’m lookin for looks good how’s the ride never had BFGoodrich before I have the 285/55/20 Hankooks that came with mine.
Yes. Stock size. So far they are great, much better than the junk it came with. Very comfortable ride. Just over 30k miles on them. Plenty of tread left. Great wet traction. Low noise. I'm very pleased with them
Sent from my SM-G973U using Tapatalk
Thanks for the reply mine never leaves the pavement just getting some feedback
  • 3 weeks later...
Just installed Raceline Boost wheels in bronze with 285/70/17 tires.  17x9 with 0 offset.  I have a 1” level and have zero rubbing.
  • Like 3
2016 Silverado 1500 4x4  2" Level, Air Bags in rear and Monroe Load Lifters
285/65/18 Nitto Terra Grapplers on 18" Tahoe Stocks
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
