Edit mispost.
Edited by 5RWill
You must not understand offset. While I love negative offset too, the reason guys are able to run 35s with a leveling kit with minor rubbing is because they are usually on stock wheels, or wheels that have a positive offset and a large amount of backspacing. This keeps the wheel in as you turn, keeping it away from the inner fender. With a -24, I'm guessing you'd be on a 20x10, 33x12.50 are probably going to rub a bit with just a leveling kit. to run 35s you'd probably have to go full 5"+ kit. Going to have to be more than a leveling kit though. I hope you understand what I'm saying, trying to make it as clear as I can.
Edit: I have a -12 on my truck and they only clear by about 3/4" with half tread 285/50/20.
Diameter is going to be largely based on the height of the truck. For these new Sierras/Silverados you'll likely have to have a 5-7" lift to accommodate 35" tires, and even then you might have to trim.
Fitting the width of the tire is largely controlled by offset. The higher the offset the more inward the tire will be in the wheel well. The lower the offset the further the wheel will stick out from the wheel well allowing larger width tires to be accommodated so you don't rub the UCA, Coil Spring, or the sway bar. If your planning on running 12-12.5" width tires your going to need 0 to -12 offset minimum.
I don't know anyone running 35x12.5x20 on stock rims without trimming or rub. It's why 295/55/20 rubs on stock rims and it's going to as the OEM stock 20s for these trucks are +27mm offset.
http://cocomponents.com/dealer/blog/wheel-offset-explained/
I totally understand offset. Yes I get a very slight rub at full lock on the sway bar.
I have alot of room for turning, 3"+ between fenders on each side
If you think you can do it then go for it. I don't think it'll work at all, but if you have tons of room snd measured, try it
I will have the test fit it and report back. I am running a procomp 2.5" Level . Just any one is following this
Probably going to buy these tomorrow and throw them on this weekend.
2.5 level with -24 offset and a 35" tire...get ready to trim and trim heavily.
I think if I run the 35" tire. I am going to have to run the stock +31 offset.
If I stick with the 33" tire. I think I should be able to clear the -24. I am not sure.
With a 33"/-24 you may rub a little while turning or may clear. But you'll have to trim still because of rubbing when you turn going over bumps. On my truck for example I could have not trimmed nearly as much as I did. But with the way I trimmed I can be at full lock forward or reverse and go over and size bump and not rub on anything.
Could you post a picture of how you trimmed crafferty?
What's the difference between going forward or reverse? I understand how bumps would make a difference but never understood how someone can run at full lock in reverse and not at all in drive even at full lock.
I know a few ppl have mentioned that they only run at full lock in reverse and not in drive.
Just put on some Sierra wheels that have the PVD Black Chrome finish.
Now, I need to change to an AT better looking tire.
Need opinions on what size and tire to get.
I plan to stay at stock height all around
Should I go with
275/60/20 33.0"
285/55/20 32.3"
305/50/20 32.0"
Edited by Rawyzf
Here are the pictures. Let me know if you need any in particular.
The two big differences are the direction in which you turn the wheel. You can't know you don't rub until you go full lock in both drive and reverse and turn it both ways as well. It also helps to have someone watch the wheel and tire as you turn it. The other thing is sometimes in drive you can slightly rub but never hear it because its essentially rubbing with the grain. Where as in reverse you go against the grain and any part rubbing will make more noise when it hits the tread.
Edited by crafferty
Good point on the going against the grain. Never thought of that part.
Should I go with
275/60/20 33.0"
285/55/20 32.3"
305/50/20 32.0"
Looks good! The actual sizes on the truck will be about 1" lower than the specs on the mfg's sites list. I have 275-60-20 Toyo AT2's and they are 32" tall maybe 31 7/8th's so the others will be even shorter once mounted.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
