You might also want to replace the tires if they're POS Goodyear's.
Agree there. Might be different now, but the Goodyears that came on my 2011 didn't do it any favors.
I have a 2WD crew cab. Truck rides well, but I've noticed the front has a lot of "bounce" to it when going over bumps. Back end seems to absorb shock appropriately, but the front is too slushy for my liking. Just going up my driveway my truck sways and bounces. My 2012 didn't respond like this.
Edited by CL8N
Bilstein 4600's and call it a day. They have LD and HD versions.
Shockwarehouse.com
Agreed, going to swap mine out for the 4600's when they become available!!!
Has anyone tried these ?
Pro Runner Series Shock Absorber
By Pro Comp Suspension $74.99 (each)
available now from "4 WHEEL PARTS" 800-257-5629 for 2014 CHEV - 1500
Overview :
Pro Comp's Pro Runner Monotube Shocks are designed specifically for late model trucks, Jeeps and SUVs. The gas charged, monotube design delivers
superior performance over traditional twin tube, hydraulic shocks. The vehicle specific ride tuning was derived after extensive dyno and real-world testing.
The result is multi-stage valving that optimizes ride quality and handling characteristics for your specific application. The brushed, Zinc plated, clear coated,
monotube shock body is nitrogen gas charged to eliminate performance-robbing cavitation during compression and rebound, allowing the shock to dissapate
heat more efficiently, drastically reducing shock fade. Whether you are towing a trailer or hitting whoops in the desert, you can count on Pro Comp's Pro Runner
Shocks to give you the confidence behind the wheel.
I thought I might toss a pair on the rear, see how they are.
Edited by desert
Overview :
If you're willing to wait, Bilsteins should be about the same price, are also nitrogen charged monotube design, but you get the peace of mind of an industry leading brand and model shock. Just my $0.02.
Bilstein 5100s (or 4600s) all the way. Have them on my Tacoma, and will put them on whatever truck I have from here on out.
Overview :
As multiple other people here are trying to tell you wait for Bilstein to make a shock for your model truck. Your ranchos will be fine until they release something as those pro comps I don't think will fair much better then your current shocks.
I had Ranchos first and Pro Comps second on my Ford 4X4 1 ton, both of them gave up the ghost in short order. Did the last 40K before I sold it on Bilsteins - no problems.
Edited by Last C5
+1 ... don't waste your time on Pro Comps, Skylacker or any "lift company" shocks. They all suck the same. Bilstein smokes them all..
The factory shocks on my 2014 2wd crew cab suck-the GM valving is horrible. I'm patiently waiting for Bilsteins. The biggest issue I have is they have way too little high speed rebound and the truck takes too long to settle over bumps (some of you might describe this as floaty).
I'm no Rancho fan but the factory Rancho shocks on Z71's are likely built to GM specs with GM valving.
Edited by RobZ71LM7
Exactly the issue I'm experiencing. My 2012 wasn't like this. I enjoy the smooth ride while driving though.
kinda suspension related question.
is there any stiffer sway bars that we can get?
i know, its a truck, meant to have body roll and flex off-road. the only off-roading i will be doing is some trails that are just not considered provincial roads, ill be 80% just driving around highways, 10 towing and 10 some very easy trails
is there a 2wd or 4x4 SS version of our trucks with sway bars?
Hellwig has a 1.5" front sway bar available and an adjustable 1.125" rear sway bar. I've already ordered both. A lot of people just install a rear on the trucks, but there are huge gains to be made up front as well. I'm hoping these combined with new shocks will put the truck where I want it. But the shocks still have to go.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
