2015 towing mirrors
Bringing back from the dead.
GM Accessories is working on a towing mirror kit for K2 trucks. Should be out soon. Black and Chrome. So, for those that are looking into putting tow mirrors on and that have patience, give it a couple months.
  • Replies 504
Hello,
Newbie to the forum and newbie GMC owner. Recently purchased a 2014 Denali HD 6.6L TURBO DIESEL - used with 8K miles. I purchased it to tow a 37 foot travel trailer camper which we are newbie with too. The power fold mirrors on this truck are awful - so small - I can't imagine towing with them. I just ordered power fold camper mirrors. The mirrors will be in tomorrow but reading through this thread I'm worried these mirrors will not fit my truck. Can you provide any insight as to whether or not the mirrors I ordered will fit and fully function. The GM part numbers I ordered are:
23241465
23241467
They weren't cheap so hope these will fit my truck.
Thanks in advance for any help!
Best Regards,
Bob
Hello,
23241465
23241467
Best Regards,
Bob
Welcome to the forums, Bob!
The mirrors you ordered appear to be the ones for 2014-2015 style trucks (K2s). Since you have a 2014 GMT-900 HD truck, I don't think they will fit.
Don't panic just yet though, I may be wrong! I just don't think anyone has tried putting the new mirrors in the older trucks yet.
This is good news, hopefully it simplifies the process for those of us that prefer to stay away from doing the independent wiring.
Keep us posted if you hear anything further.
Hello,
23241465
23241467
Best Regards,
Bob
Will not fit your truck. Those are for K2 which are 2014 and up 1500 and 2015 and up HD trucks. Different mirror mount base becuase the doors are different between the two style trucks. You need tow mirrors for the 2007-2014 HD body style which is the style truck you have. GM sells those mirrors in a kit. You need part # 19243900. It comes with two mirrors and a mirror switch which must be replaced and possibly programmed to the truck. Hopefully you can toss those ones you ordered on eBay or this site.
Will do.
... GM Accessories is working on a towing mirror kit for K2 trucks. ...
GM Accessories? Do you have a url for that company?
They wont fit. New have 4 mounting pins, old have 3.
That's not the problem. The 2014+ 1500's only have 3 mounting studs too. You drill out a (factory pre-marked) hole in the door to install the mirrors.
The problem is the shape of the door is different.
And you are correct! The mirrors came in today with four mounting posts as discussed. But the footprint is completely different - there's no way this is mounting on to my truck! Ugh...
GMDirect said they'll take these back and refund me without a stocking fee. But this doesn't solve my power fold dilemma. Does anyone have experience with these mirrors? The customer service rep said they are power folding...
http://www.carid.com/2014-gmc-sierra-denali-side-mirrors/k-source-system-lane-change-alert-system-44780866.html#product-details-tab
Not as pretty as the OEM power folding mirrors but...
Thanks for everyone's input!
Best Regards,
Bob
Best Regards,
Bob
I don't think those are power folding. Just "foldable". Plus they are ugly. Were there not mirrors like you want available as OEM?
I agree - they are ugly. Apparently there are no OEM power folding mirrors for 2014 HD.
Update: The GM kits that are coming are the new style mirrors, with the spot lights, the LED markers, and either chrome or black.
I really hope they can get everything ( lights, LEDs, etc.) plug and play for us folks with the early 2015's. I appreciate the update regardless!!
Has anyone tried integrating the power fold components into a manual mirror? Basically keeping the footprint of a manual fold, which fits the 2014 HD, and modify it to accept the power folding motor and whatever other components - casing, extension rails and mirror/lights assy - and integrate them with the manual fold footprint.
Any advice on this would be much appreciated. I haven't returned the mirrors as of yet because I just think they're so cool!
Thanks,
Bob
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
