Then just follow the instructions in this thread. I thought you meant about working in drive
Its the exact same for the 2500 as this thread?
Did the mod to add reverse lights with cargo switch using the 1N4004 diode on my 16 and my dad's 17. Worked great.
I did this on my 2015 and worked great! just got a 2017 Crew and can't get it to work. Different terminals? Canadian vehicle? Z71? I'm at a loss.
Try and turn your cargo light on at night while in reverse
I've looked at the BCM detail for 2017 and they are the same. You check to make sure:
- the orientation of the diode is correct?
- each end is making good contact with the terminal?
Here is a close up detail. Connection is between the brown and pink plugs.
Did mine up a few weeks ago.
Never read anything, heard anything, nor noticed since doing this mod, that when you put your truck into reverse, the cargo light indicator lights up.
What is the indicator light? I have a 2014 and there is not a light.
hmm, now i need to go see this. haha
Thanks for responding to his question.
Yeah, like I said, was a little surprised.
Went to dinner with my son last night, he noticed it and started to freak out about it.
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
