Nice! I have em too. Probably the best investment I've made in the truck.
100%. Night and day difference and the blue looks pretty in there
Oh yeah. The blue and bronze works for some reason.
On 6/24/2019 at 4:24 PM, loganck97 said:
Almost done with mine. Need some kind of bed cover.
I love what you did with the front bumper my friend!
On 6/24/2019 at 7:15 PM, jgraves13 said:
Jgraves what steps are you rockin?
Also here's my summit white 17
Not a good picture but this is the latest picture I have that I took the night I got my new tires and wheels on.
Plasti-Dipped emblems
305/55/20 BFG on Tuff A/T Wheels
Raised keys 1.5"
Tow mirrors
Magnum RT Steps
Tonneau Cover
Stubby Antenna
On ‎7‎/‎12‎/‎2019 at 8:59 PM, jimmyboy8301 said:
Looks like you have dinner in the background haha
